> Which would you choose?, Subie w/325 hp or 2.8 massive IV with 225 hp
hot_shoe914
post Jun 28 2008, 09:59 PM
on ramp passer
Okay I have come to a point where I am in a delima. I have a '73 2.0 car with the appearance group package that has had all 911 suspension upgrades and I will also be adding GT flares. I was originally going to put a 2.8 IV in it with about 225 horses but now am considering a subie engine putting out about 325 horses or more. I have always been a purist but there is something to be said for smoking the competion through the curves and also being able to dust the muscle cars down the highways. I can get into the 2.8 for around 7000.00 for motor and tranny minus installation. I can get into the subie for about 4800.00 minus installation.
What are the thoughts and opinions out there along with the pros and cons for each. All input would be greatly appreciated.
Donald
CliffBraun
post Jul 3 2008, 03:21 AM
QUOTE(grantsfo @ Jul 2 2008, 12:29 PM)
Best choice of all for a 914-4 owner that plans street and some AX is to just go with a nice 2056 and pass on the drag racing. Why not keep thae car as close to stock as possible to retain reliability that was engineered by true engineers rather than barn yard bandits.
As a newbie here, I probably don't add much weight to this discussion, however I'm an ME in training and a big part of that is understanding the trade offs. In my 914 I ended up going for as low mass as possible (also low polar moment), so I was torn between a built Type I and a Type IV. I ended up going with the Type IV because of cost and because of classing.
I've no experience with Jake's engines, but I am suspicious of someone promising those gains and using such language. Anyone who shadow boxes about the engines they build (2.8 type IV is good/ we don't build those often, so you can't use them against us) is kinda stringing you along. Promising two different things based on different engines is kinda a misleading way to do business.
Anyways, I don't mean to rip on Raby, double speak kinda irritates me ever since I read 1984 though. My planned set up is a 2.0 with slightly longer connecting rods, and nicer internals to produce a great deal more torque without sacrificing reliability.
I decided not to go with a 2.4 (not even a 2.8!) because of reliability issues, Andrew broke a 2.4 at an autocross, and I didn't want the slightest chance of that happening. That said, I would be nervous as hell with a 2.8....
Much less one built by someone with a God complex.
I'd be happy to give more details about what I'm building provided the people building it don't have a problem with that. I am very much of the opinion that the advantage in the 914 is being able to maintain velocity through corners, rather than putting a big flippin' engine in it. Ever seen a V8 conversion win an autox?
Just one PS, your response to Chris' comment is complete shit, the entire thread is about a big Type IV, and you comment "Thats why we don't do that. Most all our engines make their power with a 96mm bore that slides right into the stock, non machined case."
To me that's hugely misleading, again, the entire thread is "big IV vs other engine" and you're responding with how the small Type IV is great....
Yeah, most of your engines don't do that, but that's what he's talking about building; I could give a damn if your 1.8 produces infinity horses reliably; a 2.8(especially based on the same case) is an entirely different story.
Incidentally, my no holds barred 914 is a Pauter engine running on methanol, as far as I've read nothing Raby builds can come close. You have to design (or copy) mounts, but it's still better than paying a ton for snake oil that bolts to your stock mounts.
Lemme know how I'm wrong so I can fix myself.
grantsfo
post Jul 3 2008, 09:31 AM
Arrrrhhhh!
QUOTE(CliffBraun @ Jul 3 2008, 02:21 AM) *
Yes please more details! I know we have some awesome T4 developers here on West Coast but they have profesionalism to stay off public 914 forums and focus on their work. I'd love to start hearing about other builders and what they are doing with the T4.
There certainly is the money and enthusiasm on the West Coast for a premier T4 builder to emerge. I'd go to a T4 if I could find somone I could trust to buid a motor for me in California. I have the T4 case I was going to use for a Raby motor a couple years ago sitting in my garage.
Now that I'm focusing primarily on AX I may go back to T4 again. But I want something that will put out 200 HP and rev to 7500 RPM.
This post has been edited by grantsfo: Jul 3 2008, 09:35 AM
Chris Hamilton
post Jul 3 2008, 10:59 AM
QUOTE(grantsfo @ Jul 3 2008, 08:31 AM) *
He's getting a rabbit-rods 2.0 built by my dad. He had quite a bit of budget for the project, so we spent quite a while playing with various ideas. Type 1 engines, Type 4 engines, v8s, 6-cylinders, inline 4 cylinders, and the most cost effective solution ended up being the long-rods 2-liter. It uses the stock mounts ( obviously ), runs on pump gas, never leaks, never overheats, revs to 8,000 , and should last him a good 10-20 years of daily driving. The engine ends up being wider than a normal 2.0, but you can still adjust the valves with it in the car.
james2
post Jul 3 2008, 11:34 AM
Have you had good luck with the rabbit rods?
I know in type 1 motors they are frown upon because they take so much material from the rod journal. This reduces the overlap on the journals and weakens the crank.
The rabbit rod is only 46mm compared to the stock 50mm size for a type 4 and 55 mm for a type 1
BTW, plenty of people are running the 2 inch ( 50.8mm) chevy ( actually Buick 215 ci) journal in both engines.
QUOTE(Chris Hamilton @ Jul 3 2008, 08:59 AM) *
hot_shoe914   Which would you choose?   Jun 28 2008, 09:59 PM
auerbach   Jake -- hands down   Jun 28 2008, 10:02 PM
orange914   if i had it to do over i'd definately go with ...   Jun 28 2008, 10:06 PM
Phoenix 914-6GT   Well, I think it really depends on you really. I w...   Jun 28 2008, 10:23 PM
r_towle   Serious question. How old are you? I have found t...   Jun 28 2008, 10:30 PM
orange914   I would think you could do a six for less than 1...   Jun 28 2008, 11:18 PM
JRust   Since I have gone to the dark side with my current...   Jun 28 2008, 11:17 PM
TC 914-8   Well, My opinion Having a 400 hp V8 now, and Havin...   Jun 28 2008, 11:29 PM
Todd Enlund   When I got my car, I wanted to do a Subie. You ha...   Jun 28 2008, 11:48 PM
Chuck   When I got my car, I wanted to do a Subie. You h...   Jul 3 2008, 12:52 PM
dw914er   what subie motor are you doing? a newer wrx motor...   Jun 29 2008, 01:57 AM
URY914   If you go with Jake's engine you get a new mot...   Jun 29 2008, 07:10 AM
Vacca Rabite   This is so much personal choice. For my car, I bu...   Jun 29 2008, 07:20 AM
Paul Illick   You can get a 220 hp 2.8 from Jake for seven grand...   Jun 29 2008, 08:11 AM
dw914er   You can get a 220 hp 2.8 from Jake for seven gran...   Jun 30 2008, 02:58 AM
zymurgist   Can you get a 325 hp Subaru that won't require...   Jun 29 2008, 08:27 AM
turboman808   Thats a tough one. I personally would prefer to h...   Jun 29 2008, 08:52 AM
james2   Wow, i remember getting in a big flame war over pu...   Jun 29 2008, 10:13 AM
rhodyguy   there's something to be said of the sound the ...   Jun 29 2008, 11:53 AM
WLD419   Wow! tough decision , which ever one you chose...   Jun 29 2008, 02:03 PM
hot_shoe914   First off I want to thank everybody for their inpu...   Jun 30 2008, 02:40 AM
Jake Raby   Nope.. Thats no fun at all. When I chose to mo...   Jun 30 2008, 07:24 AM
r_towle   Nope.. Thats no fun at all. When I chose to m...   Jun 30 2008, 08:59 AM
Paul Illick   The 2.8 TIV will cost more than 7K. The engine KI...   Jun 30 2008, 10:55 AM
ericread   As an older guy, I really prefer a 914 that is as ...   Jun 30 2008, 10:43 AM
TeenerTim   The only water in a 914 should be in the window wa...   Jun 30 2008, 11:58 AM
dw914er   Jake, I was refering to Steve (i think his profile...   Jun 30 2008, 12:39 PM
SirAndy   Which would you choose? Subie w/325 hp or 2.8 mas...   Jun 30 2008, 01:23 PM
Phoenix 914-6GT   Which would you choose? Subie w/325 hp or 2.8 ma...   Jun 30 2008, 02:22 PM
Jake Raby   those may be fast cars that have well built engine...   Jun 30 2008, 01:24 PM
zymurgist   those may be fast cars that have well built engin...   Jun 30 2008, 02:18 PM
Jake Raby   those may be fast cars that have well built engi...   Jun 30 2008, 08:29 PM
toon1   I was is this posistion also. Not for the reason o...   Jun 30 2008, 01:56 PM
Phoenix 914-6GT   I was is this posistion also. Not for the reason ...   Jun 30 2008, 02:20 PM
toon1   I was is this posistion also. Not for the reason...   Jun 30 2008, 05:55 PM
zymurgist   Why did Porsche start putting WC engines in their...   Jul 2 2008, 06:22 AM
Phoenix 914-6GT   more horse power. They felt they could create more...   Jun 30 2008, 06:24 PM
dw914er   more horse power. They felt they could create mor...   Jun 30 2008, 07:16 PM
Todd Enlund   more horse power. They felt they could create mor...   Jun 30 2008, 09:34 PM
toon1   more horse power. They felt they could create mor...   Jun 30 2008, 08:03 PM
Jake Raby   Aviation engines operate in cooler ambient temps.....   Jun 30 2008, 09:40 PM
turboman808   Never had a problem with overheating. :confused:   Jun 30 2008, 10:25 PM
Jake Raby   And the heads were hotter because of the restricti...   Jul 2 2008, 12:05 PM
james2   " it's hell being right all the time,...   Jul 2 2008, 12:16 PM
Zundfolge   Seems to me if you plan on doing any racing, a Rab...   Jul 2 2008, 12:57 PM
grantsfo   I think you will find that a 3.2 or 3.6 liter six ...   Jul 2 2008, 01:29 PM
ericread   I think you will find that a 3.2 or 3.6 liter six...   Jul 2 2008, 03:03 PM
Jake Raby   I'd bet that if YOU knew ANYTHING about them...   Jul 2 2008, 03:04 PM
Zundfolge   Honestly I don't understand the Type IV hate. ...   Jul 2 2008, 04:49 PM
Jake Raby   Imagine that.. And of course, Grant will always...   Jul 2 2008, 04:53 PM
james2   You have not arrived until you get your own person...   Jul 2 2008, 05:42 PM
rtalich   You have not arrived until you get your own perso...   Jul 2 2008, 06:10 PM
grantsfo   Hmmm seems to me that someone thinks they are only...   Jul 2 2008, 06:38 PM
Jake Raby   Hmmm seems to me that someone thinks they are onl...   Jul 2 2008, 08:15 PM
grantsfo   I wonder why he chose a 4 cylinder?? Oh well,...   Jul 2 2008, 09:54 PM
LarryR   I still think a 2056 T4, Porsche six or a subie ...   Jul 2 2008, 10:19 PM
SirAndy   ... I really think that there is a point where if...   Jul 3 2008, 03:29 PM
Chris Hamilton   Hmmm seems to me that someone thinks they are onl...   Jul 2 2008, 08:29 PM
james2   That's the way i look at, the government is bu...   Jul 2 2008, 08:57 PM
Jake Raby   Thats why we have been referring to our engines f...   Jul 2 2008, 09:08 PM
Jake Raby   OK, looks like Grant has taken his Prozac and all ...   Jul 2 2008, 10:04 PM
Phoenix 914-6GT   :popcorn: Gonna have to agree with Grant on this o...   Jul 2 2008, 10:10 PM
Jake Raby   I agree that above the 220 HP level "other...   Jul 2 2008, 10:38 PM
LarryR   I agree that above the 220 HP level "other...   Jul 2 2008, 10:55 PM
michaelt55   I figured I'd chime in as a person who has own...   Jul 2 2008, 10:52 PM
Jake Raby   Mike, thanks for the post.. The Boxster and 996 e...   Jul 2 2008, 10:56 PM
CliffBraun   Best choice of all for a 914-4 owner that plans s...   Jul 3 2008, 03:21 AM
Phoenix 914-6GT   Best choice of all for a 914-4 owner that plans ...   Jul 3 2008, 04:14 AM
LarryR   Just one PS, your response to Chris' comment ...   Jul 3 2008, 08:55 AM
grantsfo   I'd be happy to give more details about wha...   Jul 3 2008, 09:31 AM
Chris Hamilton   Yes please more details! I know we have som...   Jul 3 2008, 10:59 AM
james2   Have you had good luck with the rabbit rods? I k...   Jul 3 2008, 11:34 AM
grantsfo   Yes please more details! I know we have so...   Jul 3 2008, 02:52 PM
Chris Hamilton   What will you guys do for heads? Anything speci...   Jul 3 2008, 05:46 PM
grantsfo   What will you guys do for heads? Anything spec...   Jul 3 2008, 09:43 PM
Chris Hamilton   That would be cool! I would defintely like ...   Jul 3 2008, 10:04 PM
Phoenix 914-6GT   I also think that we need to give a lot of credit...   Jul 4 2008, 01:33 AM
michaelt55   Best choice of all for a 914-4 owner that plans ...   Jul 3 2008, 03:43 PM
Jake Raby   Cliffbraun, If I were you I'd get a few more t...   Jul 3 2008, 08:57 AM
Jake Raby   Nothing wrong with Rabbit rods at all... Some of t...   Jul 3 2008, 01:09 PM
Jake Raby   Creating an 8,000 RPM 2 liter is a lot easier tha...   Jul 3 2008, 03:41 PM
J P Stein   The Boxster & 996 engines are history. Porsche...   Jul 3 2008, 07:12 PM
jd74914   Cliff, lets hear some more about the Paulter rodde...   Jul 3 2008, 07:33 PM
Chris Hamilton   Cliff, lets hear some more about the Paulter rodd...   Jul 3 2008, 08:45 PM
Paul Illick   IMHO dyno charts are better than words. Speculat...   Jul 3 2008, 09:04 PM
grantsfo   I have an idea! Instead of a Subi or a Raby g...   Jul 3 2008, 10:00 PM
Spoke   Back to the original question: Big 4 or Subi; It d...   Jul 4 2008, 07:18 AM
Paul Illick   If you want as much HP as possible AND you like t...   Jul 4 2008, 09:01 AM
jimkelly   all i can say is that we are very lucky to be able...   Jul 4 2008, 09:39 AM
Paul Illick   Never mentioned is the sound of a V8 car. People ...   Jul 4 2008, 10:36 AM
Chris Hamilton   Never mentioned is the sound of a V8 car. People...   Jul 4 2008, 05:13 PM
jimkelly   the sound - absolutley - just last week i used my ...   Jul 4 2008, 11:21 AM
grantsfo   Sixes are pretty sweet sounding too. http://www.y...   Jul 4 2008, 11:36 AM
jimkelly   i doubt anyone disagrees with you that six-es soun...   Jul 4 2008, 01:23 PM
- Lo-Fi Version Time is now: 20th November 2026 - 11:43 PM
