Monday, 11 August 2025 |
stephenaki |
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None ![]() |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Case is split! (IMG:style_emoticons/default/biggrin.gif) So after we ran around this morning, I finally got to work on the motor some more. You know, Haynes isn't kidding when they say if it doesn't come apart easily there is still a bolt or nut somewhere that you missed! Good lord! I hope I can remember where the hell all the nuts and bolts go!
I did find the missing cylinder pieces, they got kinda chopped up and pieces were in the sump as Zach predicted. So, I did some reading after I split the case and, someone correct me if I am wrong, based on the rods on the crank I would say that I have a 1.7 crank and rod set. Picture below. (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2475.jpg) Anyone think otherwise? So here then is my question for the group and I am looking for your thoughts and recommendations. Based on the fact that the head register was machined out to accommodate the larger cylinders but the crank and connecting rods are for a 1.7 vice 2.0. What is the way ahead? I am assuming I can't take her back down to a 1.7 and, based on Jakes article on his site, the 1.7 crank and connecting rods don't work very well with the 2.0 cylinder and re-machined heads. Recommendations on the way ahead? My gut feeling is to pony up the dough and get a 2.0 crankshaft and just build a semi stock 2.0 with correct cylinders, pistons and connecting rods. What say ye oh omnipotent 914 Meisters? (IMG:style_emoticons/default/pray.gif) Finally the distributor gear has some nicks, photo below, major problem or can I just lightly file the sucker and smooth it out? I am assuming I will just use the existing gears on the 1.7 crank if I transfer to a 2.0 crank. (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2469.jpg) For those that want more engine porn, the link to my photo bucket album is as follows: Steve's 914 photo bucket album Looking forward to hearing some suggestions from the group. |
Lo-Fi Version | Time is now: 11th August 2025 - 02:16 PM |
