914fun |
Member ![]() ![]() Group: Members Posts: 107 Joined: 22-June 08 From: Joplin MO Member No.: 9,201 Region Association: Southwest Region ![]() |
I just purchased a 1971 and the p.o. said they did not come with high beams. But when I look at the wiring in the haynes it shows it with two eliments like a high and low beam but I cant fined any switches for it in the car. How can this pass inspection. I have no horn and the wiring in the hayns dosnt show one, whats up with that?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I have no horn and the wiring in the hayns dosnt show one sure it does ... (IMG:style_emoticons/default/rolleyes.gif) item 64, showing a black/yellow and brown/white wire. black/yellow is 12V from fuse 9 going to the horn, brown/white is ground going to the steering column horn button. as for the highbeams, your PO is wrong. they are run through a relay which you activate by moving the turn signal lever towards you. you should hear the relay click ... (IMG:style_emoticons/default/bye1.gif) Andy |
Lo-Fi Version | Time is now: 10th June 2024 - 12:10 PM |
