| amallagh |
Jul 16 2008, 05:13 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 4-September 06 From: Cheshire, England Member No.: 6,767 |
I've recently converted my 914-6 to a 2.4S spec engine with PMO 40 carbs.
The engine/heads are standard S spec but with 2.2S pistons giving about 9.3:1 compression rather and the std 8.5:1. Can any one recommend a specific cam profile/supplier that is optimised for use on carbs with an S spec engine ? If the std S cams from an MFI engine are considered to the the best for this application then I would be happy to hear your experiences. I'm looking for a fast road cam to give me similar performance to the std S cams on MFI. The car is used on the road as well as for competition, so I need something smoothy and tractible at low RPM. Regards Andrew |
| brant |
Jul 16 2008, 05:28 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Andrew,
have you driven an S cam MFI vehicle? if so is that tractable enough and smooth enough for you at low rpm? most of the competition (racing) cars will go with a cam even more aggressive than an 'S' for competition use but they loose some of the low end tractability so if you need something more tractable, then step down to a Solex if the S cam tractability will work for you, it is a wonderful choice (plus the 2.4 extra displacement tends to mellow out the 's' cam in comparison to a smaller 2.0 displacement) if you want more horsepower and can give up some of the tractability then go for a GE60, or GE80, or GE100 the GE100 is probably way too much for anything streetable or below 7-8,000 rpm and not what your looking for. brant |
| ArtechnikA |
Jul 17 2008, 06:52 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
...so if you need something more tractable, then step down to a Solex if the S cam tractability will work for you, it is a wonderful choice if you want more horsepower and can give up some of the tractability then go for a GE60, or GE80, or GE100 I agree the S cam is probably the hot setup once you learn to use some revs to get the car off the line. early MFI E's good too, and the Solex's are always nice. The GE cams are 4-bearing camshafts, so I believe you're looking at some machine work on the cam boxes to make them work. |
amallagh Camshaft recommendation for PMO'd 2.4S ? Jul 16 2008, 05:13 PM
J P Stein Solex or E cams are the cat's ass for a street... Jul 16 2008, 06:01 PM
396
Solex or E cams are the cat's ass for a stree... Jul 16 2008, 07:29 PM
scotty b +1 for Solex :driving: S is great once you hit 6... Jul 16 2008, 08:14 PM
Phoenix-MN :agree: B)-->
Root_Werks
:agree: B)--><div class='quotetop... Jul 24 2008, 11:21 AM
amallagh Excuse my ignorance but what exactly in a Solex gr... Jul 17 2008, 03:01 PM
Phoenix-MN I think "Solex" was coined from the very... Jul 17 2008, 04:16 PM
ArtechnikA
I think "Solex" was coined from the ver... Jul 17 2008, 06:27 PM
amallagh Great info, thankyou.
So is the Solex cam specifi... Jul 17 2008, 07:02 PM
ArtechnikA
So is the Solex cam specifically optimised for us... Jul 17 2008, 07:39 PM
J P Stein The big "problem" with S cams is duratio... Jul 17 2008, 07:31 PM
ArtechnikA
MFI delivers fuel below the butterflies and has t... Jul 17 2008, 07:46 PM
J P Stein Tho I can't prove it, I suspect the MFI, S com... Jul 17 2008, 08:38 PM
scotty b
Tho I can't prove it, I suspect the MFI, S co... Jul 17 2008, 08:43 PM
ArtechnikA
Tho I can't prove it, I suspect the MFI, S co... Jul 17 2008, 09:51 PM
brant You've opened a big mystery box now
there are ... Jul 17 2008, 08:42 PM
ArtechnikA
by the way, you can get GE grinds for 3 bearing s... Jul 17 2008, 10:01 PM
brant
did we ever establish if those are available for ... Jul 17 2008, 10:09 PM
ArtechnikA
I know they exist
I wish I knew you were looking
... Jul 17 2008, 11:47 PM
amallagh So if I glean some of the different opinions expre... Jul 18 2008, 03:23 AM
ArtechnikA
If the Solex cam is ideal for a PMO set up with S... Jul 18 2008, 05:32 AM
J P Stein Like most of these old parts (or old style), findi... Jul 18 2008, 07:29 AM
ArtechnikA
I forget exactly where I got these....no matter, ... Jul 18 2008, 10:13 AM
J P Stein The "ideal" cams for carbs would be the ... Jul 18 2008, 07:49 AM
J P Stein 40s...sorry about the lousy pic. :D Jul 18 2008, 05:01 PM
ArtechnikA
Actually it... Jul 18 2008, 05:14 PM
TimT Amallagh,
I have a set of WebCam 158R grind cams,... Jul 18 2008, 07:29 PM
amallagh
Amallagh,
I have a set of WebCam 158R grind cams... Jul 23 2008, 04:30 PM
6freak
Amallagh,
I have a set of WebCam 158R grind cam... Jul 24 2008, 10:42 AM
TimT I forgot to add, I have dyno plots somwhere of t... Jul 18 2008, 07:38 PM
J P Stein Hay, Tim, that is a good buy. Jul 18 2008, 09:20 PM
6freak
Sent the man a P... Jul 23 2008, 09:47 AM
sixnotfour the cam card is listed on the website, looked at i... Jul 24 2008, 10:48 AM
amallagh
the cam card is listed on the website, looked at ... Jul 24 2008, 01:29 PM
J P Stein Solex & S cams have the same 97 deg lobe cent... Jul 24 2008, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:39 PM |
