> Camshaft recommendation for PMO'd 2.4S ?
amallagh
post Jul 16 2008, 05:13 PM
I've recently converted my 914-6 to a 2.4S spec engine with PMO 40 carbs.
The engine/heads are standard S spec but with 2.2S pistons giving about 9.3:1 compression rather and the std 8.5:1.
Can any one recommend a specific cam profile/supplier that is optimised for use on carbs with an S spec engine ?
If the std S cams from an MFI engine are considered to the the best for this application then I would be happy to hear your experiences.
I'm looking for a fast road cam to give me similar performance to the std S cams on MFI. The car is used on the road as well as for competition, so I need something smoothy and tractible at low RPM.
Regards
Andrew
brant
post Jul 17 2008, 08:42 PM
You've opened a big mystery box now
there are lots of tricks, and lots of ways to get the most out of it.
and it really all boils down to intended use:
what RPM will you really be at
street or race, because you can't maximize both....
by the way, you can get GE grinds for 3 bearring set ups
most of the guys I know run GE60's on the street
and most of the guys I race with run GE100's (on 1967 2.0/6 motors)
you can really really help jetting by using IDS style auxillary enrichment devices, and also by running tall 2ndary venturi's
you can work around flat spots by changing primary venturi's or changing gearing.
not to mention the use of a wideband type system to actually get it perfect.
I do all of the above
I love the auxillary enrichment tubes, and I run an F/J/O/S/V gearbox that leaves me in the power band at all times...
amallagh   Camshaft recommendation for PMO'd 2.4S ?   Jul 16 2008, 05:13 PM
brant   Andrew, have you driven an S cam MFI vehicle? if...   Jul 16 2008, 05:28 PM
ArtechnikA   ...so if you need something more tractable, then ...   Jul 17 2008, 06:52 AM
J P Stein   Solex or E cams are the cat's ass for a street...   Jul 16 2008, 06:01 PM
396   Solex or E cams are the cat's ass for a stree...   Jul 16 2008, 07:29 PM
scotty b   +1 for Solex :driving: S is great once you hit 6...   Jul 16 2008, 08:14 PM
Phoenix-MN   :agree: B)-->
QUOTE(scotty b ...   Jul 16 2008, 08:19 PM
Root_Werks   :agree: B)--><div class='quotetop...   Jul 24 2008, 11:21 AM
amallagh   Excuse my ignorance but what exactly in a Solex gr...   Jul 17 2008, 03:01 PM
Phoenix-MN   I think "Solex" was coined from the very...   Jul 17 2008, 04:16 PM
ArtechnikA   I think "Solex" was coined from the ver...   Jul 17 2008, 06:27 PM
amallagh   Great info, thankyou. So is the Solex cam specifi...   Jul 17 2008, 07:02 PM
ArtechnikA   So is the Solex cam specifically optimised for us...   Jul 17 2008, 07:39 PM
J P Stein   The big "problem" with S cams is duratio...   Jul 17 2008, 07:31 PM
ArtechnikA   MFI delivers fuel below the butterflies and has t...   Jul 17 2008, 07:46 PM
J P Stein   Tho I can't prove it, I suspect the MFI, S com...   Jul 17 2008, 08:38 PM
scotty b   Tho I can't prove it, I suspect the MFI, S co...   Jul 17 2008, 08:43 PM
ArtechnikA   Tho I can't prove it, I suspect the MFI, S co...   Jul 17 2008, 09:51 PM
brant   You've opened a big mystery box now there are ...   Jul 17 2008, 08:42 PM
ArtechnikA   by the way, you can get GE grinds for 3 bearing s...   Jul 17 2008, 10:01 PM
brant   did we ever establish if those are available for ...   Jul 17 2008, 10:09 PM
ArtechnikA   I know they exist I wish I knew you were looking ...   Jul 17 2008, 11:47 PM
amallagh   So if I glean some of the different opinions expre...   Jul 18 2008, 03:23 AM
ArtechnikA   If the Solex cam is ideal for a PMO set up with S...   Jul 18 2008, 05:32 AM
J P Stein   Like most of these old parts (or old style), findi...   Jul 18 2008, 07:29 AM
ArtechnikA   I forget exactly where I got these....no matter, ...   Jul 18 2008, 10:13 AM
J P Stein   The "ideal" cams for carbs would be the ...   Jul 18 2008, 07:49 AM
J P Stein   40s...sorry about the lousy pic. :D   Jul 18 2008, 05:01 PM
ArtechnikA   40s...sorry about the lousy pic. Actually it...   Jul 18 2008, 05:14 PM
TimT   Amallagh, I have a set of WebCam 158R grind cams,...   Jul 18 2008, 07:29 PM
amallagh   Amallagh, I have a set of WebCam 158R grind cams...   Jul 23 2008, 04:30 PM
6freak   Amallagh, I have a set of WebCam 158R grind cam...   Jul 24 2008, 10:42 AM
TimT   I forgot to add, I have dyno plots somwhere of t...   Jul 18 2008, 07:38 PM
J P Stein   Hay, Tim, that is a good buy.   Jul 18 2008, 09:20 PM
6freak   Hay, Tim, that is a good buy. Sent the man a P...   Jul 23 2008, 09:47 AM
sixnotfour   the cam card is listed on the website, looked at i...   Jul 24 2008, 10:48 AM
amallagh   the cam card is listed on the website, looked at ...   Jul 24 2008, 01:29 PM
J P Stein   Solex & S cams have the same 97 deg lobe cent...   Jul 24 2008, 07:06 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:44 PM
