| amallagh |
Jul 16 2008, 05:13 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 4-September 06 From: Cheshire, England Member No.: 6,767 |
I've recently converted my 914-6 to a 2.4S spec engine with PMO 40 carbs.
The engine/heads are standard S spec but with 2.2S pistons giving about 9.3:1 compression rather and the std 8.5:1. Can any one recommend a specific cam profile/supplier that is optimised for use on carbs with an S spec engine ? If the std S cams from an MFI engine are considered to the the best for this application then I would be happy to hear your experiences. I'm looking for a fast road cam to give me similar performance to the std S cams on MFI. The car is used on the road as well as for competition, so I need something smoothy and tractible at low RPM. Regards Andrew |
| amallagh |
Jul 18 2008, 03:23 AM
So if I glean some of the different opinions expressed here then the Solex cam is better optimised for a carbed engine then the S profile.
The reduced overlap seemed to be one of the factors that drove this so I surprised to see someone suggesting GE cams profiles which I thought had a lot of overlap. But maybe they were talking just for pure racing and weren't worried about the low to mid range. On a comparative basis then I would still be interested if anyone had any experience of the relative peak power outputs of E, Solex and S cams on a Weber/PMO 2.4 with S heads. I understand that the absolute power depends on other factors. (In have PMOs with 40/34 venturi, std S heads & ports with 1.5" Bursch headers and a fairly std Bursch 911 exhaust to keep the noise down for use on track) I see people saying that it is 'impossible' to optimise things for track and road, and of course this is correct. But I am looking for that compromise set up for a road car that is also used for some competition use. My decision appear to be whether to go for another set of S cams or change to the Solex or E cams if I'm trying to improve the mid range a little without compromising the top end too much. That's why I'm interested in some estimate of the relative peak power outputs of the 3 choices. If the Solex cam is ideal for a PMO set up with S heads then the next question if where to I get a new or reground pair at a reasonable price ? |
| ArtechnikA |
Jul 18 2008, 05:32 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
If the Solex cam is ideal for a PMO set up with S heads then the next question if where to I get a new or reground pair at a reasonable price ? Web-CamDo the Product Search, select Automobile, Porsche, 911 SOHC 12valve, and you get a nice page of options. At the top is the 1966 Solex profile, which per the July 2008 price update are US$718 in hard-weld, $878 on new billet. All the popular profiles are the same price, as you'd expect. To do it right, you'll also need 12 matched rockers - WebCam will hard-weld and grind your cores for $65 each. They list rebushing separately. The Euro is at historic rates vs the US$. Strike while the iron is hot. ( I have no personal affilliation with WebCam, and they don't need me to shill for them. ) |
amallagh Camshaft recommendation for PMO'd 2.4S ? Jul 16 2008, 05:13 PM
brant Andrew,
have you driven an S cam MFI vehicle?
if... Jul 16 2008, 05:28 PM
ArtechnikA
...so if you need something more tractable, then ... Jul 17 2008, 06:52 AM
J P Stein Solex or E cams are the cat's ass for a street... Jul 16 2008, 06:01 PM
396
Solex or E cams are the cat's ass for a stree... Jul 16 2008, 07:29 PM
scotty b +1 for Solex :driving: S is great once you hit 6... Jul 16 2008, 08:14 PM
Phoenix-MN :agree: B)-->
Root_Werks
:agree: B)--><div class='quotetop... Jul 24 2008, 11:21 AM
amallagh Excuse my ignorance but what exactly in a Solex gr... Jul 17 2008, 03:01 PM
Phoenix-MN I think "Solex" was coined from the very... Jul 17 2008, 04:16 PM
ArtechnikA
I think "Solex" was coined from the ver... Jul 17 2008, 06:27 PM
amallagh Great info, thankyou.
So is the Solex cam specifi... Jul 17 2008, 07:02 PM
ArtechnikA
So is the Solex cam specifically optimised for us... Jul 17 2008, 07:39 PM
J P Stein The big "problem" with S cams is duratio... Jul 17 2008, 07:31 PM
ArtechnikA
MFI delivers fuel below the butterflies and has t... Jul 17 2008, 07:46 PM
J P Stein Tho I can't prove it, I suspect the MFI, S com... Jul 17 2008, 08:38 PM
scotty b
Tho I can't prove it, I suspect the MFI, S co... Jul 17 2008, 08:43 PM
ArtechnikA
Tho I can't prove it, I suspect the MFI, S co... Jul 17 2008, 09:51 PM
brant You've opened a big mystery box now
there are ... Jul 17 2008, 08:42 PM
ArtechnikA
by the way, you can get GE grinds for 3 bearing s... Jul 17 2008, 10:01 PM
brant
did we ever establish if those are available for ... Jul 17 2008, 10:09 PM
ArtechnikA
I know they exist
I wish I knew you were looking
... Jul 17 2008, 11:47 PM
J P Stein Like most of these old parts (or old style), findi... Jul 18 2008, 07:29 AM
ArtechnikA
I forget exactly where I got these....no matter, ... Jul 18 2008, 10:13 AM
J P Stein The "ideal" cams for carbs would be the ... Jul 18 2008, 07:49 AM
J P Stein 40s...sorry about the lousy pic. :D Jul 18 2008, 05:01 PM
ArtechnikA
Actually it... Jul 18 2008, 05:14 PM
TimT Amallagh,
I have a set of WebCam 158R grind cams,... Jul 18 2008, 07:29 PM
amallagh
Amallagh,
I have a set of WebCam 158R grind cams... Jul 23 2008, 04:30 PM
6freak
Amallagh,
I have a set of WebCam 158R grind cam... Jul 24 2008, 10:42 AM
TimT I forgot to add, I have dyno plots somwhere of t... Jul 18 2008, 07:38 PM
J P Stein Hay, Tim, that is a good buy. Jul 18 2008, 09:20 PM
6freak
Sent the man a P... Jul 23 2008, 09:47 AM
sixnotfour the cam card is listed on the website, looked at i... Jul 24 2008, 10:48 AM
amallagh
the cam card is listed on the website, looked at ... Jul 24 2008, 01:29 PM
J P Stein Solex & S cams have the same 97 deg lobe cent... Jul 24 2008, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:35 PM |
