| tornik550 |
Jul 17 2008, 09:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have weber 40 idf carbs with a bugpack linkage. Is there supposed to be a spring on the accelerator pedal that returns the pedal idle or are the springs on the carbs the only springs to return the pedal to idle?
Thanks again- Steve |
| Cap'n Krusty |
Jul 18 2008, 08:59 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Too much spring can be worse, for the car, than no spring at all. Before you spend the money, check the pedal bushings and the cable itself. The Cap'n
| rebelmdot |
Jul 18 2008, 09:37 AM
914ini ![]() ![]() Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
Cap'n, I am relatively new to this, and I did this in an effort to solve the problem of poor return that I was having. Can you elaborate on what potential problems I could have by putting that big spring on? Thanks.
Too much spring can be worse, for the car, than no spring at all. Before you spend the money, check the pedal bushings and the cable itself. The Cap'n |
tornik550 Accelerator will not return to idle Jul 17 2008, 09:24 PM
rebelmdot Spring on Carb is the only one. I had similar pro... Jul 17 2008, 09:40 PM
tornik550
Spring on Carb is the only one. I had similar pr... Jul 18 2008, 07:29 AM
rebelmdot I made that little piece to accomodate the large s... Jul 18 2008, 07:51 AM
tornik550
I made that little piece to accomodate the large ... Jul 18 2008, 08:18 AM
SGB I have Webers, but use 3 springs; one at the end o... Jul 17 2008, 09:54 PM
jmill He's got a single and you have duals. If you ... Jul 18 2008, 08:38 AM
rhodyguy :agree: x2 w/the cap'n on this one. the cable ... Jul 18 2008, 11:20 AM
davep The pedal itself should provide some spring action... Jul 18 2008, 11:33 AM
Vacca Rabite The Weber tech manual for VW applications suggests... Jul 18 2008, 11:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st November 2026 - 02:32 PM |
