Fun While it Lasted, Teener Sidelined Tonight |
rebelmdot |
Jul 18 2008, 10:29 PM
914ini Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
Well, after having sat for 6 years in the guys yard that I bought it from, I got Tisch running in 5 days. On her maiden voyage all of the shift bushings that were brittle apparently shattered. No gears at all. So last Saturday I spent 3 hours changing all of them out and adjusting and fine tuning the shift linkage. R-1-2-3-4-5 all worked like a charm. I put 200 miles on her this week, and all of a sudden on the way home from work this evening on the highway NO GEARS. I even tried pulling off of the road, turning the car off and putting the car in gear while off, but when I turned key, car lunged forward and I had clutch pedal to the floor. I do not know at this point if it is the cable or in the clutch itself, I will have to get under tomorrow to see. Those were the best 200 miles I have driven in 10 years!!! Any thoughts on potential areas for troubleshooting let me know. (IMG:style_emoticons/default/headbang.gif)
TheCabinetmaker |
Jul 19 2008, 02:57 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
If the cable lets go, the pedal falls to the floor. If the pedal has resistance( lifts itself off the floor ), and it lurches forward anyway when you start it in gear, Then it is a problem with the clutch itself. As for the shifting, If you tried to shift it with no clutch, it would most likely grind and make lots of noise. 200 miles after you replaced the bushings? I would also check that the cone screws have not loosened up.
Lo-Fi Version | Time is now: 1st June 2024 - 11:06 PM |
