Rare 914-6 911-4 914 1970 turbo 911 transaxle |
736conver |
Jul 23 2008, 12:44 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RTQ:MOTORS:1123 1970 turbo 911 didnt know they existed 911-4 well thats a 912. cloned 914-6 ...is there a vin (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
Jul 23 2008, 07:44 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If there was a clearer picture you might be able to tell.
It could be the two year only ('70 - '71) 911/901 box converted to use in a 914. This conversion allows you to use the stock 225 mm "pull" clutch instead of the 215 mm 914/6 clutch. It would also give you more compatible gearing for a six cylinder engine. |
ClayPerrine |
Jul 23 2008, 11:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,522 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If there was a clearer picture you might be able to tell. It could be the two year only ('70 - '71) 911/901 box converted to use in a 914. This conversion allows you to use the stock 225 mm "pull" clutch instead of the 215 mm 914/6 clutch. It would also give you more compatible gearing for a six cylinder engine. Ron, you are right, but that box is NOT a 70/71 tranny with a 914 tail housing. If it was, it wouldn't have the clutch cable pulley on it. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:32 AM |
