What am I leaving on the table with this combo? |
Badass43 |
Jul 25 2008, 08:56 AM
Newbie Group: Members Posts: 26 Joined: 11-June 08 From: Louisiana Member No.: 9,163 Region Association: None |
Hey Guys,
I have a 2.0 that I am trying to put back together on a budgit. Here is what I am thinking on doing with it. It now has 96mm dished P/C and a 86A cam. I really don't want to split the case so I may just put a new set of rods and bearings, get the cylinders honed, put a new set of rings (who sells these?), replace all seals and gaskets. For the heads, mine are in need of repair so to save that $1,000.00 or so I can get some what I am told VW type IV 2.0 heads that are I guess are buss heads that have new valves, seats and guides for a fraction of the price to have my 2.0 heads reworked. The heads that were on the engine had the head gaskets installed so I may just buy some cylinder spacers the same thickness and use those and do away with the head gaskets. I will be using dual dellorto 40 carbs off of my 1.8L. My question is, with this combo how much H.P. am I leaving on the table and how do you think this combo will perform for street use? I'm not into racing just a weekend car and sometimes driving to work on nice days. Will I have any kind of heat problems using the cam that is in it now? I have read a few things about the power band being in the upper RPM range using the 86A cam. Will this cam be a problem for street use and what would be the max RPM for this combo? What kind of improvement do you think I would see compared to my stock 1.8L with the dual carbs? Randy |
r_towle |
Jul 25 2008, 02:39 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Think about using the 1.8 liter heads.
They are less prone to crack than the 2.0 liter heads...so really a new set of seats and bigger valve will do the trick. ALOT of old school guys will use the 1.8 liter head...(these are STOCK VW heads from a bus or 411) The plug placement is not perfect, but when properly setup with the right valves and a little port work they do produce quite a bit of power. Before everyone steps up to the communal bench engineering podium.... I have had two motors produce 200HP using 1.8 liter heads as the base (original plug location) Yes they had bigger valves and they were set up on a flow bench. these are not new techniques...these heads were done in the late 70's and I posted flow charts back a few years ago... Bottom line...if the 2.0 liter heads are to far gone...you may save some money using the 1.8 liter heads. 130-140 hp can be made using these heads and 2.0 liter valves. Rich |
G e o r g e |
Jul 25 2008, 04:09 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
(IMG:style_emoticons/default/hijacked.gif)
Before everyone steps up to the communal bench engineering podium.... I have had two motors produce 200HP using 1.8 liter heads as the base (original plug location) Yes they had bigger valves and they were set up on a flow bench. these are not new techniques...these heads were done in the late 70's Rich what were the other aspects of these motors? cylinder size, carbs? stroke? 200 at the flywheel or rear wheels? (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 11:42 AM |
