What am I leaving on the table with this combo? |
Badass43 |
Jul 25 2008, 08:56 AM
Newbie Group: Members Posts: 26 Joined: 11-June 08 From: Louisiana Member No.: 9,163 Region Association: None |
Hey Guys,
I have a 2.0 that I am trying to put back together on a budgit. Here is what I am thinking on doing with it. It now has 96mm dished P/C and a 86A cam. I really don't want to split the case so I may just put a new set of rods and bearings, get the cylinders honed, put a new set of rings (who sells these?), replace all seals and gaskets. For the heads, mine are in need of repair so to save that $1,000.00 or so I can get some what I am told VW type IV 2.0 heads that are I guess are buss heads that have new valves, seats and guides for a fraction of the price to have my 2.0 heads reworked. The heads that were on the engine had the head gaskets installed so I may just buy some cylinder spacers the same thickness and use those and do away with the head gaskets. I will be using dual dellorto 40 carbs off of my 1.8L. My question is, with this combo how much H.P. am I leaving on the table and how do you think this combo will perform for street use? I'm not into racing just a weekend car and sometimes driving to work on nice days. Will I have any kind of heat problems using the cam that is in it now? I have read a few things about the power band being in the upper RPM range using the 86A cam. Will this cam be a problem for street use and what would be the max RPM for this combo? What kind of improvement do you think I would see compared to my stock 1.8L with the dual carbs? Randy |
Dave_Darling |
Jul 25 2008, 09:52 AM
Forget the Bus heads. IIRC, they will really screw up your compression ratio, since the chamber volume is uite different than the 914 2.0 heads. They also have small valves and not very good ports. You're leaving a lot on the table if you use them.
--DD |
craig downs |
Jul 26 2008, 04:47 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Forget the Bus heads. IIRC, they will really screw up your compression ratio, since the chamber volume is uite different than the 914 2.0 heads. They also have small valves and not very good ports. You're leaving a lot on the table if you use them. --DD Also the bus heads crack more than the others because of the more heat generated by the extra weight and load from the bus |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:38 AM |
