| rhodyguy |
Jan 23 2006, 04:58 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
here you go. the definitive test if you're told "i'm pretty sure..."
the top one is for 75' & 76' oem style heat exchangers. 26 3/8" to the inside edge of the muffler bolt holes. i think the one pictured is bent, but the difference in appearance is obvious. the middle one is the correct one for the early style 2.0 heat exchangers. 19 1/4" to the inside edge of the muffler bolt holes. this style of h.e.'s are flat where the h.e. meets the muffler. the bottom one is for early style 1.7/1.8 heat exchangers. 21 3/16" to the inside of the muffler bolt holes. this style of h.e.'s have a kick-up at the end where the h.e. meets the muffler. always be absolutely sure of the type of heat exchangers you have when purchasing mufflers. hope this helps. k Attached image(s)
| Dave_Darling |
Jan 24 2006, 03:50 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Not the same, no, but I believe it's a drop-in replacement for it.
--DD |
| Justinp71 |
Aug 1 2008, 03:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
Not the same, no, but I believe it's a drop-in replacement for it. --DD Thats correct, its a drop in replacement. I just bought one (73-74 2.0) from Engman last week for my 914/6 original style headers. Mounted it last night and it fit fine. (IMG:style_emoticons/default/smile.gif) |
| Root_Werks |
Aug 1 2008, 03:04 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,092 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Not the same, no, but I believe it's a drop-in replacement for it. --DD Thats correct, its a drop in replacement. I just bought one (73-74 2.0) from Engman last week for my 914/6 original style headers. Mounted it last night and it fit fine. (IMG:style_emoticons/default/smile.gif) I think the difference is the 914-6 has closed holes while the 914-4 has the "U" or open ended hole. I thought I had in my possesion at one time a 914-6 hanger and remember it had closed holes. (IMG:style_emoticons/default/idea.gif) |
rhodyguy is that really a early 2.0 muffler hanger Jan 23 2006, 04:58 PM
Aaron Cox quick reference drawing for the archives...... Jan 23 2006, 05:20 PM
Mueller great pictures, should be added to the "classics".... Jan 23 2006, 05:21 PM
rhodyguy that's why i gave the measurements. if a selle... Jan 23 2006, 05:24 PM
itsa914 http://www.914world.com/bbs2/... Jan 23 2006, 07:31 PM
Headrage Anybody need 1 each of item "A"? Jan 23 2006, 07:34 PM
rhodyguy i think i have 3 http://www.914wo... Jan 23 2006, 07:38 PM
Bleyseng Isn't "B" also a 914/6 muffler hanger? ... Jan 23 2006, 08:47 PM
ClayPerrine FWIW... for years we (Betty and I) have been calli... Jan 24 2006, 08:16 AM
Root_Werks <... Jan 24 2006, 08:34 AM
rhodyguy some day, when i learn to add links, i'd add o... Aug 1 2008, 08:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 01:44 PM |
