Regulator panel wiring, T4 connector |
zonedoubt |
Aug 2 2008, 03:08 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The T4 connector on the regulator/relay panel is not marked to indicate which connector is which. Can someone confirm if I've numbered these correctly. I think they are because the yellow wire is supposed to go to T4-2 which is one of the two rear connections.
According to the electrical schematic T4-2 and T4-4 are tied together and go to ignition switch. On my car, there is a black wire (see photo) which leads to a switch under the dash which is connected to the fuel pump. The engine was carb'ed which I have removed and reinstalled the fuel injection. According the schematic T4-1 and T4-3 go a "power supply relay" which I assume is how the fuel pump is currently operated. I'm going to set the fuel pump circuit up how it's supposed to be. Any advice? |
ejm |
Aug 2 2008, 04:48 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Which FI system are you installing? They are not wired the same. "Yellow wire" is L-jet which does not use the relays on the board. The pump is powered by the dual relay. Look at the AFC/MPC diagrams here. T4 pinout in the pic below.
Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 08:31 AM |
