| brer |
Aug 3 2008, 02:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
My pal Don at the Bugpatch is going to be setting up to do some Type 4 heads in the next week or two. I'm having 2 sets done myself and thought others might need some good quality heads done..... reasonable prices as well if you just need stock work done.
He did a set of 1.7L heads for me with guides, seats, reground valves and 3 angle valve job for $400 last year and they run perfectly. Bugpatch Type 4 Price list The Bug Patch 9470 W. Heaney Circle Santee, CA 92071 Phone: 619-449-8670 Mention 914World (IMG:style_emoticons/default/smile.gif) |
| brer |
Aug 5 2008, 01:57 PM
Total Enchilada pricing for 914world members
the prices are the same for 1.7, 1.8, & 2.0. 1. Total Enchilada- all new seats, guides, swirl polished stainless SI valves, new exhaust studs, bead blast, surface, and 3angle valve job, your springs tested and replaced w/ matched if needed - per pair of T-4 $650.00 per pair. 2. Using reground stock intake and new SS exhaust valves $570.00 per pair. (Same package but w/out performance valves) 3. Using reground stock intake and new exhaust valves and no exhaust stud repair are $410.00 per pair. (Same package but w/out performance valves or exhaust studs) 4. Basic service, same as 3 but w/out new seats. $250per pair + Add $200.00 for cnc porting per pair. This does not include any other repairs like cracks, threads, or welding which can add a $100 or so. Seats used are modern composite jobs and are compatible with modern fuels. 1.7L heads can get a bump in valve size with total enchilada for no charge + Crack repairs are about $40.00- $60.00 each and might also need chamber cutting $50.00 per head and or exhaust cutting $30.00 + thread repairs are $20.00- $30.00 each + welding is $20.00 minimum to $100.00 per hour. + New springs are $40.00 per set if you don't have your own selection, or you can use your old ones. Turn around time of 2-4 weeks |
| retrofit |
Aug 5 2008, 06:45 PM
Member ![]() ![]() Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 |
Total Enchilada pricing for 914world members the prices are the same for 1.7, 1.8, & 2.0. 1. Total Enchilada- all new seats, guides, swirl polished stainless SI valves, new exhaust studs, bead blast, surface, and 3angle valve job, your springs tested and replaced w/ matched if needed - per pair of T-4 $650.00 per pair. 2. Using reground stock intake and new SS exhaust valves $570.00 per pair. (Same package but w/out performance valves) 3. Using reground stock intake and new exhaust valves and no exhaust stud repair are $410.00 per pair. (Same package but w/out performance valves or exhaust studs) 4. Basic service, same as 3 but w/out new seats. $250per pair + Add $200.00 for cnc porting per pair. This does not include any other repairs like cracks, threads, or welding which can add a $100 or so. Seats used are modern composite jobs and are compatible with modern fuels. 1.7L heads can get a bump in valve size with total enchilada for no charge + Crack repairs are about $40.00- $60.00 each and might also need chamber cutting $50.00 per head and or exhaust cutting $30.00 + thread repairs are $20.00- $30.00 each + welding is $20.00 minimum to $100.00 per hour. + New springs are $40.00 per set if you don't have your own selection, or you can use your old ones. Turn around time of 2-4 weeks (IMG:style_emoticons/default/aktion035.gif) Hey ther Brer You are on the ball! Are you in marketing? Just kidding. When you know of some good people it's good to spread the word. Will keep this rebuilder in mind. AK |
brer Cylinder Head Rebuilding Aug 3 2008, 02:50 PM
Cap'n Krusty What, no crack repairs? Practically every set of ... Aug 3 2008, 07:01 PM
brer
What, no crack repairs? Practically every set of... Aug 3 2008, 08:11 PM
NoEcm
Type 4 head repair is like hiring a call girl. Y... Aug 3 2008, 08:58 PM
brer sample Aug 3 2008, 08:26 PM
brer Don emailed me about this thread.
"I dont us... Aug 4 2008, 11:18 AM
r_towle not do discredit anyone, but a real question.
Is ... Aug 4 2008, 11:50 AM
brer I should have clarified what it was I posted, sorr... Aug 4 2008, 12:03 PM
r_towle oh, cool.
So he has a CNC program all setup to rep... Aug 4 2008, 01:46 PM
brer He can bead blast them lightly for a fine texture,... Aug 4 2008, 01:56 PM
retrofit Thanks for the headsup re head work.
Would appreci... Aug 4 2008, 11:23 PM
retrofit
Would apprec... Aug 4 2008, 11:27 PM
McMark I don't think I've seen many (if any) CNC ... Aug 5 2008, 07:44 PM
cgnj Hi,
Don did a set of 2.0 heads for me long before... Aug 6 2008, 04:29 AM
brer getting ready to do some more heads!
this deal... Nov 24 2008, 01:09 PM
Drums66 Cool Brer........Brian Pauter(Pauter Machine)...al... Nov 24 2008, 05:19 PM
StratPlayer Thanks for the heads up. Might have some business... Nov 24 2008, 07:44 PM
brer pm me if you are thinking of having some done.
... Nov 24 2008, 09:54 PM
brer Bump :bump: Nov 28 2008, 09:11 PM
Gint Hey Brer, Does that price include any crack repai... Nov 28 2008, 11:34 PM
brer those prices are all with no crack repairs include... Nov 29 2008, 12:14 AM
Gint Duh. Been a while since I read this whole thread.... Nov 29 2008, 09:07 AM
brer as a reference, a 2.0 spark plug hole with a crac... Nov 29 2008, 06:28 PM
justme Hi BR,
I need a set of 1.7's cleaned up for... Dec 27 2008, 12:28 PM
J P Stein As a data point only.
I sent my heads to EBS racin... Dec 27 2008, 01:09 PM
wertygrog hey Brer, is this service still being offered? I h... Dec 27 2008, 04:59 PM
eric914
hey Brer, is this service still being offered? I ... Jan 15 2009, 10:25 PM
brer
hey Brer, is this service still being offered? I... Jan 20 2009, 01:06 AM
arvcube Might be time for some mexican...2-4 week turnarou... Jan 20 2009, 10:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:19 AM |
