VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I want to do my cabin. Floors, interior firewall. Not planning on doing doors.
I'll use either Fatmat or Dynamat, but I don't know how much to buy. Which of the two do people like best these days. Zach |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Mark...
Two types of rubber (you may not be able to get Grace Chemical stuff) Its easy to spot. Cured rubber is what an inner tube is...its dry. Uncured rubber is soft and can be rolled into a ball, made into any shape you want...then once cured...hold that shape. The Ice and Water shield is just uncured rubber...with a significant glue on one side that makes it stick to air, you, your hair (that one sucks) or pretty much anything...its really sticky. Touch one sticky face to the other stick face and you will learn what the work sticky really means....it fuses together instantly. One way to get it to work is freeze it...(leave it outside) Put it on a frozen surface (cold car, no heat in shop that day) You will buy a little bit of time to move it around. Then use a heat gun and it will fuse with the panel forever... I have a porch roof I built that I used the stuff on. I changed a portion of that roof and no matter what I used I could not get the stuff to seperate from the wood substrate...its amazing stuff. Same treatment goes for Dynamat...but I suspect the glue is more forgiving with Dynamat given its intended application. Rich |
retrofit |
Member ![]() ![]() Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 ![]() |
Mark... Two types of rubber (you may not be able to get Grace Chemical stuff) Its easy to spot. Cured rubber is what an inner tube is...its dry. Uncured rubber is soft and can be rolled into a ball, made into any shape you want...then once cured...hold that shape. The Ice and Water shield is just uncured rubber...with a significant glue on one side that makes it stick to air, you, your hair (that one sucks) or pretty much anything...its really sticky. Touch one sticky face to the other stick face and you will learn what the work sticky really means....it fuses together instantly. One way to get it to work is freeze it...(leave it outside) Put it on a frozen surface (cold car, no heat in shop that day) You will buy a little bit of time to move it around. Then use a heat gun and it will fuse with the panel forever... I have a porch roof I built that I used the stuff on. I changed a portion of that roof and no matter what I used I could not get the stuff to seperate from the wood substrate...its amazing stuff. Same treatment goes for Dynamat...but I suspect the glue is more forgiving with Dynamat given its intended application. Rich (IMG:style_emoticons/default/aktion035.gif) I went into Home Depot today just to see if they carried a similar product. Surprise, surprise, they carry Quick Roof. Packaged in a roll that is 6" x 25' or 12 1/2 sq ft per roll, out the door for $15.00 at $1.20 per sq ft. Cheap! And, it does have the aluminum top sheet so you are getting a multidimensional product. I'm going to install it in my '74 2.0 and the '95 Chev dually. Allen |
Lo-Fi Version | Time is now: 17th July 2025 - 03:08 AM |
