2seater4me |
Newbie ![]() Group: Members Posts: 1 Joined: 6-July 08 From: Puyallup Wa. Member No.: 9,261 Region Association: None ![]() |
Iam trying to find a rebuild kit for a 1974 1.8L with a 17mm master cylinder, any ideas ? Thanks for the help.
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,402 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Brake calipers don't wear out.
Brake pads wear out. M/C's wear out. Ever take one a part? The are rubber "cups" or seals that move inside the m/c. They wear out by rubbing on the inside walls of the m/c. Much like piston rings in a cylinder. Unless you hone the m/c AND replace the seals your rebuild will not be as good as a new one. |
Lo-Fi Version | Time is now: 11th July 2025 - 01:54 PM |
