Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
These are the heater valves that supply or dump the heat from the heat exchangers on the type 4 engine. The 914/6 valves are different, but similar. There are minor differences between these valves sold as replacement items in the 1980's and the original items installed by the factory. The dump cap is less angular and more rounded on the installed valves.
(IMG:http://www.914world.com/bbs2/uploads/post-1244-1214690960.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1244-1214690981.jpg) notice the symmetry of the clamps matches the lever arms (IMG:http://www.914world.com/bbs2/uploads/post-1244-1214690995.jpg) |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
When I put one of these side by side with a t4 VW bus heater control valve, they appear to be the same size. Only difference is the orientation, and potentially the length, of the arm. Of course this can easily be changed by drilling out the tack weld (which I've seen to break on its own), and welding the arm into the proper position.
My comparison was brief so this may not be accurate. Anyone know for sure? -Chris |
Lo-Fi Version | Time is now: 15th July 2025 - 10:25 AM |
