O2 sensor placement, Test and Tune only |
r_towle |
Aug 19 2008, 07:13 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Instead of drilling and welding in a bung for an O2 sensor prior to the muffler,(clients car) how accurate would a tailpipe extension tube with an O2 sensor be?
Im thinking of a 1 foot long tailpipe extension with the O2 sensor welded in as close to the muffler as possible, yet without touching the stock system. I intend to clamp the pipe in place with a stainless sleeve clamp so its air tight. Any thoughts? Rich |
orange914 |
Aug 19 2008, 09:32 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
as long as it's a heated o2 it should be fine, just keep it as far from the tip as possible
to lower c.o. readings, the sniffer close to the outlet trick was/is used on some shady smogs. but is hard to regulate and often gets too much oxygen. (did i say that?) (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 15th June 2024 - 01:21 PM |
