No fuel after pump relocation and SS line install |
LowGT |
Aug 19 2008, 10:10 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
This is on a stock 74 1.8 L-jet.
I just relocated the pump to the front and installed the SS lines. I'm not getting fuel to the engine, plugs are dry. I followed a post Darling made to connect the 3 port pump to the tank/ss lines. Pump turns on with key in the on position and AFM plate pressed open. Do I need to prime the system? I didn't think that was necessary since it is a return style fuel system. My only thought is a pinched fuel line under the tank after I set it in. Just wanted to see if I'm missing anything before I try to drain 5 gal of gas from under the car to lift the tank out. Dan |
r_towle |
Aug 19 2008, 10:35 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you may have put the fuel lines on backwards????
LowGT |
Aug 19 2008, 11:16 PM
you may have put the fuel lines on backwards???? Yea, I fear I may have crossed the lines under the tank or pinched a line when the tank went in. (IMG:style_emoticons/default/headbang.gif) Tank comes back out tomorrow I guess. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:42 AM |
