Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
I have a carbed 2.7 in my 914/6.....my question is on the heater hoses that come off of the fan.
The hoses attach to twin ducts that then pass thru the engine tin to the heat exchangers below. Fresh air supplied by the fan then flows through the HEs and go to the flapper valves and into the ducting into the cab.... Do the hoses go through the tin by themselves in one piece? Or do they use a rolled piece of tin at the sheet metal, attached with hose clamps, making it a two piece hose on each side? My thinking is that by going through as a one piece hose the sharp edges of the tin would tend to rub and cut into the hose? If there is a rolled tube, what is the part # or does someone have a picture so that I can fabricate something..... OR is there a rubber grommet there, OR what....? |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(mikez @ Jan 7 2004, 11:29 PM) ... Do the hoses go through the tin by themselves in one piece?... yes. i thought there were supposed to be big soft rubber grommets on the holes in the tin, but like a lot of the German rubber, it cracked, dried up, and broke off in the heat/UV/ozone SoCal environment... anyway i can't find any reference to those grommets in the usual listings so maybe i hallucinated the whole thing. you might get some vacuum hose and slit it, making a big grommet, or get some 'caterpiller grommet' at an electronic supply store. of just run your dogleg deburring tool aaround the top and bottom surface of each hole and decree it good enough ... |
Lo-Fi Version | Time is now: 16th June 2024 - 05:10 PM |
