No fuel after pump relocation and SS line install |
LowGT |
Aug 19 2008, 10:10 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
This is on a stock 74 1.8 L-jet.
I just relocated the pump to the front and installed the SS lines. I'm not getting fuel to the engine, plugs are dry. I followed a post Darling made to connect the 3 port pump to the tank/ss lines. Pump turns on with key in the on position and AFM plate pressed open. Do I need to prime the system? I didn't think that was necessary since it is a return style fuel system. My only thought is a pinched fuel line under the tank after I set it in. Just wanted to see if I'm missing anything before I try to drain 5 gal of gas from under the car to lift the tank out. Dan |
McMark |
Aug 20 2008, 12:27 PM
Don't pull the tank, just put the front on jackstands (observe safety procedures here), pull off the steering rack cover, reach up into the access hole on the passenger side and feel the lines. Feel for kinks. I can usually pull the lines out of the access hole and leave them dangling then test fire the motor. Once I'm sure it runs fine, then carefully stuff the lines back into the hole.
Lo-Fi Version | Time is now: 8th June 2024 - 10:02 AM |
