No fuel after pump relocation and SS line install |
LowGT |
Aug 19 2008, 10:10 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
This is on a stock 74 1.8 L-jet.
I just relocated the pump to the front and installed the SS lines. I'm not getting fuel to the engine, plugs are dry. I followed a post Darling made to connect the 3 port pump to the tank/ss lines. Pump turns on with key in the on position and AFM plate pressed open. Do I need to prime the system? I didn't think that was necessary since it is a return style fuel system. My only thought is a pinched fuel line under the tank after I set it in. Just wanted to see if I'm missing anything before I try to drain 5 gal of gas from under the car to lift the tank out. Dan |
ClayPerrine |
Aug 20 2008, 12:28 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Pull the gravel pan that is under the steering rack. Reach in the hole on the right side and see if you can feel a pinched fuel line.
If you get the lines too long when putting the tank in, they will pinch. If you pinch the suction line you will not get fuel pressure. BTDT.. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:35 AM |
