> Carb throat popping at speed, New Problem!!!
LetoAtreides
post Aug 15 2008, 10:38 PM
Ok, so I know I've posted this before, but I still cant figure it out, and I need to know all of the possible circumstances under which this condition occurs.
One of the throads on my dual carbs is excessively lout at speed. It sounds like pop-pop-pop.
Any ideas?
Mark Henry
post Aug 20 2008, 03:39 PM
that's what I do!
I understand how Rich feels, the T4 doesn't like being fuched with, any lean/too much advance issue can turn it into a paperwieght real fast.
Linkage is the number one problem with dual carbs and it's always user error.
Timing 7.5 static or 28 full with a strobe, guessing is expensive and dumb, I know a heck of a lot more than most and I don't guess.
LetoAtreides   Carb throat popping at speed   Aug 15 2008, 10:38 PM
r_towle   well, its lean. How it has become lean could be al...   Aug 15 2008, 11:13 PM
drive-ability   Ok, so I know I've posted this before, but I ...   Aug 15 2008, 11:14 PM
Elliot Cannon   If it accelerates OK but starts popping when you a...   Aug 15 2008, 11:23 PM
ArtechnikA   also - check for bad, bent, or misaligned linkage....   Aug 16 2008, 09:10 AM
LetoAtreides   Update! I adjusted the linkage on one side, a...   Aug 16 2008, 04:57 PM
LetoAtreides   So i think I've pretty much fixed my popping p...   Aug 20 2008, 12:56 PM
r_towle   What is your timing set at??? Rich   Aug 20 2008, 01:11 PM
LetoAtreides   I timed it using an electronic tach. I rotated th...   Aug 20 2008, 02:15 PM
ArtechnikA   Normally I am a very patient person but this has p...   Aug 20 2008, 03:26 PM
Mark Henry   I understand how Rich feels, the T4 doesn't li...   Aug 20 2008, 03:39 PM
LetoAtreides   Sorry for testing your patience, ArtechnikA, let m...   Aug 20 2008, 05:26 PM
ArtechnikA   I'm 19 years old and learning to work on my o...   Aug 20 2008, 07:07 PM
LetoAtreides   Thanks for the info. How much is a smidge? is i...   Aug 20 2008, 10:32 PM
r_towle   I will try to clarify. Step one. Static time the ...   Aug 20 2008, 10:52 PM
LetoAtreides   Ok, cool. I checked the points and dwell angle ve...   Aug 20 2008, 11:03 PM
ArtechnikA   27, 28 - that's probably as close as most of u...   Aug 21 2008, 06:47 AM
rhodyguy   i suggest you limp or tow your car to High Perfoma...   Aug 21 2008, 09:15 AM
LetoAtreides   Yeah, I've done business with Rich, and he...   Aug 21 2008, 01:39 PM
LetoAtreides   Ok, so I timed my car by the book, and it idles a ...   Aug 22 2008, 05:17 PM
ArtechnikA   Ok, so I timed my car by the book, and it idles a...   Aug 22 2008, 06:28 PM
LetoAtreides   Dellorto: main jet 36 Venturii 140 I don't kn...   Aug 22 2008, 09:20 PM
ArtechnikA   Dellorto: main jet 36 Venturii 140 Ahhh - no. Th...   Aug 23 2008, 07:00 AM
LetoAtreides   Ok, sorry about the bogus numbers. I thought the ...   Aug 23 2008, 10:39 AM
LetoAtreides   Ok, main jet is 140 pump jet is 35 I'll have t...   Aug 23 2008, 10:48 AM
LetoAtreides   idle jet is 55 throat is 40 sparks are nice and b...   Aug 23 2008, 05:28 PM
ArtechnikA   Tried driving it a bit today and no backfires whi...   Aug 24 2008, 07:09 AM
rhodyguy   what are the flow #s as indicated on your synchron...   Aug 24 2008, 07:46 AM
- Lo-Fi Version Time is now: 19th July 2025 - 08:23 PM
