> uh oh my frame is a sagin! what to do?
JOE M
post Aug 19 2008, 06:30 PM
Uhhhhhh Ohhhhhhhhhh
My passenger door is sagging and I need an inexpensive way to fix it. My goal is not to have a show car but a decent driver ( without a sagging frame). I do not think it is too bad yet but the passenger door is deffinently off. I placed a jack under the front and when I raised the car the door aligned prety good. I have attached a couple of pics if it helps. It looks like the P.O did some work because the the outter portion of the long looks fairly good. Also I removed the carpet to see if that revealed anything and it looks pretty good. I can not see anything from inside the car but under there is some rust. It does not look as bad as some that I have seen but I am not an expert by any means. Any suggestions on what I could do to get by.
r_towle
post Aug 20 2008, 07:19 PM
Custom Member
bottom of long has been patched and welded
Inner long has been welded to floor
hello hole bottom has been welded...
Overall I think you are fine, just a bit of tweeking and ALOT of elbow grease to clean the current rust and undercoat it...
Rich
JOE M   uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:30 PM
JOE M   RE: uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:34 PM
Jeff Hail   Visual clues concern me. What I cannot see i...   Aug 19 2008, 06:56 PM
dr914@autoatlanta.com   in stock rocker clamshells are down and dir...   Aug 19 2008, 06:56 PM
JOE M   in stock rocker clamshells are down and di...   Aug 19 2008, 07:04 PM
r_towle   Where are you located in NH??? I am just south of ...   Aug 19 2008, 07:29 PM
JOE M   some one anyone please help. Do I need to remove a...   Aug 19 2008, 07:29 PM
r_towle   some one anyone please help. Do I need to remove ...   Aug 19 2008, 07:35 PM
Todd Enlund   Your longs dont look bad from the pics, but they ...   Aug 19 2008, 07:46 PM
r_towle   Your longs dont look bad from the pics, but they...   Aug 19 2008, 07:55 PM
Bartlett 914   [quote name='Todd Enlund' post='1068990' date='Au...   Aug 19 2008, 08:19 PM
Wes V   Joe; Jump on the offer that Towle has made!...   Aug 19 2008, 07:50 PM
JOE M   Rich the car is carbureated so the computer is pro...   Aug 20 2008, 05:46 AM
SirAndy   Show us a pic of the hell hole and the floor pan f...   Aug 19 2008, 07:31 PM
Vacca Rabite   I don't suppose it is something as simple as t...   Aug 19 2008, 09:03 PM
Phoenix 914-6GT   I don't suppose it is something as simple as ...   Aug 19 2008, 10:29 PM
roadster fan   I don't suppose it is something as simple as ...   Aug 20 2008, 01:01 AM
JOE M   Rich I am in Hudson N.H. I live off of RT3a just b...   Aug 20 2008, 05:43 AM
Vacca Rabite   Well, if it does turn out to be a broken backbone,...   Aug 20 2008, 07:18 AM
JOE M   Well, if it does turn out to be a broken backbone...   Aug 20 2008, 07:59 AM
r_towle   Joe only lives about ten minutes from my shop... I...   Aug 20 2008, 08:13 AM
6freak   Uhhhhhh Ohhhhhhhhhh My passenger door is sagging ...   Aug 20 2008, 08:36 AM
JOE M   Rich is the man!!! He will be stoping ...   Aug 20 2008, 10:23 AM
rjames   Rich is the man!!! He will be stoping...   Aug 20 2008, 01:12 PM
JOE M   I offered him beer ,wine, and even a rib eye steak...   Aug 20 2008, 01:16 PM
Vacca Rabite   No question - you are doing this the right way. R...   Aug 20 2008, 02:13 PM
JOE M   No question - you are doing this the right way. ...   Aug 20 2008, 06:33 PM
sww914   We also need to see the area directly above the ar...   Aug 20 2008, 06:40 PM
r_towle   bottom of long has been patched and welded Inner l...   Aug 20 2008, 07:19 PM
Vacca Rabite   bottom of long has been patched and welded Inner ...   Aug 20 2008, 07:27 PM
r_towle   when I get there I will take a look. I think we ca...   Aug 20 2008, 08:02 PM
JOE M   From the response I think it sounds prommising. He...   Aug 21 2008, 05:16 AM
r_towle   nope, I live in Dunstable and my shop cant really ...   Aug 21 2008, 08:09 AM
Cevan   nope, I live in Dunstable and my shop cant really...   Aug 21 2008, 07:39 PM
r_towle   Joe's car is fine. Looks like alot of welding ...   Aug 22 2008, 06:10 PM
SGB   :trophy::trophy::trophy::trophy::trophy::trophy::t...   Aug 22 2008, 06:54 PM
Vacca Rabite   Awesome. zach   Aug 22 2008, 09:22 PM
sww914   THAT'S what this place is all about! Cool...   Aug 22 2008, 10:02 PM
dlestep   cut holes and put yer feet through 'em   Aug 22 2008, 10:17 PM
Rand   B Sure. Please. Take it deeper and be sure. Crunch...   Aug 22 2008, 10:21 PM
JOE M   Thanks for stoping by Rich I do appreciate it. I s...   Aug 24 2008, 09:02 AM
rjames   I'm not questioning the final verdict, but I k...   Aug 24 2008, 01:03 PM
r_towle   not sure what he is talking about.. I jumped up an...   Aug 24 2008, 08:11 PM
JOE M   Rich, I did get the o-rings and started to adjust ...   Aug 25 2008, 05:39 AM
r_towle   Rich, I did get the o-rings and started to adjust...   Aug 25 2008, 10:44 AM
ericread   WOW! Kudos to Rich for performing the on-sit...   Aug 25 2008, 09:44 AM
- Lo-Fi Version Time is now: 13th July 2025 - 07:36 PM
