> Carb throat popping at speed, New Problem!!!
LetoAtreides
post Aug 15 2008, 10:38 PM
Ok, so I know I've posted this before, but I still cant figure it out, and I need to know all of the possible circumstances under which this condition occurs.
One of the throads on my dual carbs is excessively lout at speed. It sounds like pop-pop-pop.
Any ideas?
ArtechnikA
post Aug 21 2008, 06:47 AM
rich herzog
27, 28 - that's probably as close as most of us can get - within a degree.
ALL the specs are for TOTAL ADVANCE.
You set you INITIAL ADVANCE (what static timing sets...) to the TOTAL number.
The INITIAL (static) gets you close enough that the engine will start and warm up safely -- prerequisites for setting TOTAL advance with the engine running.
7° BTDC ought to be 6-8mm before TDC. It's just a guideline.
In the many threads on timing a T-IV it's noted that you should IDENTIFY and CLARIFY (white paint or something) the total advance mark on the fan. Sounds like good advice. (6's are timed at the flywheel...)
27-28 degrees TOTAL advance - this will be at some elevated rpm, like (I AM GUESSING - I DONNO T-IV's) 4500.
Don't worry too much if you don't understand the concept of distributor advance yet - lots of people don't. But if you're going to be tinkering with it, you need to know (and follow) the right procedure.
LetoAtreides   Carb throat popping at speed   Aug 15 2008, 10:38 PM
r_towle   well, its lean. How it has become lean could be al...   Aug 15 2008, 11:13 PM
drive-ability   Ok, so I know I've posted this before, but I ...   Aug 15 2008, 11:14 PM
Elliot Cannon   If it accelerates OK but starts popping when you a...   Aug 15 2008, 11:23 PM
ArtechnikA   also - check for bad, bent, or misaligned linkage....   Aug 16 2008, 09:10 AM
LetoAtreides   Update! I adjusted the linkage on one side, a...   Aug 16 2008, 04:57 PM
LetoAtreides   So i think I've pretty much fixed my popping p...   Aug 20 2008, 12:56 PM
r_towle   What is your timing set at??? Rich   Aug 20 2008, 01:11 PM
LetoAtreides   I timed it using an electronic tach. I rotated th...   Aug 20 2008, 02:15 PM
ArtechnikA   Normally I am a very patient person but this has p...   Aug 20 2008, 03:26 PM
Mark Henry   I understand how Rich feels, the T4 doesn't li...   Aug 20 2008, 03:39 PM
LetoAtreides   Sorry for testing your patience, ArtechnikA, let m...   Aug 20 2008, 05:26 PM
ArtechnikA   I'm 19 years old and learning to work on my o...   Aug 20 2008, 07:07 PM
LetoAtreides   Thanks for the info. How much is a smidge? is i...   Aug 20 2008, 10:32 PM
r_towle   I will try to clarify. Step one. Static time the ...   Aug 20 2008, 10:52 PM
LetoAtreides   Ok, cool. I checked the points and dwell angle ve...   Aug 20 2008, 11:03 PM
ArtechnikA   27, 28 - that's probably as close as most of u...   Aug 21 2008, 06:47 AM
rhodyguy   i suggest you limp or tow your car to High Perfoma...   Aug 21 2008, 09:15 AM
LetoAtreides   Yeah, I've done business with Rich, and he...   Aug 21 2008, 01:39 PM
LetoAtreides   Ok, so I timed my car by the book, and it idles a ...   Aug 22 2008, 05:17 PM
ArtechnikA   Ok, so I timed my car by the book, and it idles a...   Aug 22 2008, 06:28 PM
LetoAtreides   Dellorto: main jet 36 Venturii 140 I don't kn...   Aug 22 2008, 09:20 PM
ArtechnikA   Dellorto: main jet 36 Venturii 140 Ahhh - no. Th...   Aug 23 2008, 07:00 AM
LetoAtreides   Ok, sorry about the bogus numbers. I thought the ...   Aug 23 2008, 10:39 AM
LetoAtreides   Ok, main jet is 140 pump jet is 35 I'll have t...   Aug 23 2008, 10:48 AM
LetoAtreides   idle jet is 55 throat is 40 sparks are nice and b...   Aug 23 2008, 05:28 PM
ArtechnikA   Tried driving it a bit today and no backfires whi...   Aug 24 2008, 07:09 AM
rhodyguy   what are the flow #s as indicated on your synchron...   Aug 24 2008, 07:46 AM
- Lo-Fi Version Time is now: 19th July 2025 - 08:12 PM
