> uh oh my frame is a sagin! what to do?
JOE M
post Aug 19 2008, 06:30 PM
Uhhhhhh Ohhhhhhhhhh
My passenger door is sagging and I need an inexpensive way to fix it. My goal is not to have a show car but a decent driver ( without a sagging frame). I do not think it is too bad yet but the passenger door is deffinently off. I placed a jack under the front and when I raised the car the door aligned prety good. I have attached a couple of pics if it helps. It looks like the P.O did some work because the the outter portion of the long looks fairly good. Also I removed the carpet to see if that revealed anything and it looks pretty good. I can not see anything from inside the car but under there is some rust. It does not look as bad as some that I have seen but I am not an expert by any means. Any suggestions on what I could do to get by.
r_towle
post Aug 21 2008, 08:09 AM
Custom Member
nope, I live in Dunstable and my shop cant really be seen from the road unless you really slow down..
R
Cevan
post Aug 21 2008, 07:39 PM
QUOTE(r_towle @ Aug 21 2008, 10:09 AM) *
R
Kinda of like the batcave? (IMG:style_emoticons/default/laugh.gif)
OT: Hey Rich, I got rid of most of the exhaust leak by removing the bolts between the exhaust and HEs and then re-tightening the cooper nuts (as you suggested at the CFR party). I'm guessing the remaining leak is probably the ends of the HEs not being flush with each other. I'll fix that when I put the 2.0 in this winter.
JOE M   uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:30 PM
JOE M   RE: uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:34 PM
Jeff Hail   Visual clues concern me. What I cannot see i...   Aug 19 2008, 06:56 PM
dr914@autoatlanta.com   in stock rocker clamshells are down and dir...   Aug 19 2008, 06:56 PM
JOE M   in stock rocker clamshells are down and di...   Aug 19 2008, 07:04 PM
r_towle   Where are you located in NH??? I am just south of ...   Aug 19 2008, 07:29 PM
JOE M   some one anyone please help. Do I need to remove a...   Aug 19 2008, 07:29 PM
r_towle   some one anyone please help. Do I need to remove ...   Aug 19 2008, 07:35 PM
Todd Enlund   Your longs dont look bad from the pics, but they ...   Aug 19 2008, 07:46 PM
r_towle   Your longs dont look bad from the pics, but they...   Aug 19 2008, 07:55 PM
Bartlett 914   [quote name='Todd Enlund' post='1068990' date='Au...   Aug 19 2008, 08:19 PM
Wes V   Joe; Jump on the offer that Towle has made!...   Aug 19 2008, 07:50 PM
JOE M   Rich the car is carbureated so the computer is pro...   Aug 20 2008, 05:46 AM
SirAndy   Show us a pic of the hell hole and the floor pan f...   Aug 19 2008, 07:31 PM
Vacca Rabite   I don't suppose it is something as simple as t...   Aug 19 2008, 09:03 PM
Phoenix 914-6GT   I don't suppose it is something as simple as ...   Aug 19 2008, 10:29 PM
roadster fan   I don't suppose it is something as simple as ...   Aug 20 2008, 01:01 AM
JOE M   Rich I am in Hudson N.H. I live off of RT3a just b...   Aug 20 2008, 05:43 AM
Vacca Rabite   Well, if it does turn out to be a broken backbone,...   Aug 20 2008, 07:18 AM
JOE M   Well, if it does turn out to be a broken backbone...   Aug 20 2008, 07:59 AM
r_towle   Joe only lives about ten minutes from my shop... I...   Aug 20 2008, 08:13 AM
6freak   Uhhhhhh Ohhhhhhhhhh My passenger door is sagging ...   Aug 20 2008, 08:36 AM
JOE M   Rich is the man!!! He will be stoping ...   Aug 20 2008, 10:23 AM
rjames   Rich is the man!!! He will be stoping...   Aug 20 2008, 01:12 PM
JOE M   I offered him beer ,wine, and even a rib eye steak...   Aug 20 2008, 01:16 PM
Vacca Rabite   No question - you are doing this the right way. R...   Aug 20 2008, 02:13 PM
JOE M   No question - you are doing this the right way. ...   Aug 20 2008, 06:33 PM
sww914   We also need to see the area directly above the ar...   Aug 20 2008, 06:40 PM
r_towle   bottom of long has been patched and welded Inner l...   Aug 20 2008, 07:19 PM
Vacca Rabite   bottom of long has been patched and welded Inner ...   Aug 20 2008, 07:27 PM
r_towle   when I get there I will take a look. I think we ca...   Aug 20 2008, 08:02 PM
JOE M   From the response I think it sounds prommising. He...   Aug 21 2008, 05:16 AM
r_towle   nope, I live in Dunstable and my shop cant really ...   Aug 21 2008, 08:09 AM
Cevan   nope, I live in Dunstable and my shop cant really...   Aug 21 2008, 07:39 PM
r_towle   Joe's car is fine. Looks like alot of welding ...   Aug 22 2008, 06:10 PM
SGB   :trophy::trophy::trophy::trophy::trophy::trophy::t...   Aug 22 2008, 06:54 PM
Vacca Rabite   Awesome. zach   Aug 22 2008, 09:22 PM
sww914   THAT'S what this place is all about! Cool...   Aug 22 2008, 10:02 PM
dlestep   cut holes and put yer feet through 'em   Aug 22 2008, 10:17 PM
Rand   B Sure. Please. Take it deeper and be sure. Crunch...   Aug 22 2008, 10:21 PM
JOE M   Thanks for stoping by Rich I do appreciate it. I s...   Aug 24 2008, 09:02 AM
rjames   I'm not questioning the final verdict, but I k...   Aug 24 2008, 01:03 PM
r_towle   not sure what he is talking about.. I jumped up an...   Aug 24 2008, 08:11 PM
JOE M   Rich, I did get the o-rings and started to adjust ...   Aug 25 2008, 05:39 AM
r_towle   Rich, I did get the o-rings and started to adjust...   Aug 25 2008, 10:44 AM
ericread   WOW! Kudos to Rich for performing the on-sit...   Aug 25 2008, 09:44 AM
- Lo-Fi Version Time is now: 13th July 2025 - 07:13 PM
