JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
Uhhhhhh Ohhhhhhhhhh
My passenger door is sagging and I need an inexpensive way to fix it. My goal is not to have a show car but a decent driver ( without a sagging frame). I do not think it is too bad yet but the passenger door is deffinently off. I placed a jack under the front and when I raised the car the door aligned prety good. I have attached a couple of pics if it helps. It looks like the P.O did some work because the the outter portion of the long looks fairly good. Also I removed the carpet to see if that revealed anything and it looks pretty good. I can not see anything from inside the car but under there is some rust. It does not look as bad as some that I have seen but I am not an expert by any means. Any suggestions on what I could do to get by. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Joe's car is fine.
Looks like alot of welding was done on the passenger side...fairly decent job. The jack post was never put on...but a new outer long was... Looks like the long may have shrunk a bit due to welding and the door was never adjusted properly... I showed him how to adjust it and went through a bit of talk on his carbs... Made a new 914 friend and along with his supportive wife, he will get it running like a charm..hes almost there... Rich |
Lo-Fi Version | Time is now: 13th July 2025 - 07:36 PM |
