> I need some help. Car won't rev or drive properly, I can't get any more RPMs / Power
Steve Thacker
post Aug 24 2008, 02:00 PM
UMMMPH Yea Baby Yea ! UMMMPH
I have a issue with the driveablility of my car.
First the info
1.\ 1974 2.0L engine. W/ good compression
2.\ Valves have been adjusted and double checked.
3.\ Timing set at 29dgs BTDC running Crane Optical unit, new coil, new wires, new plugs, new trigger points.
4.\ Fuel pressure at 29 lbs and remains steady (AFAIK)
5.\ TPS is new and the setting is dead on per spec.
6.\ Tested fuel injectors and they put out the desired pattern and amount. Checked connects also. They appear good.
7.\ MPS tested and all is good there.
8.\ All new vacuum hoses and they are routed to the proper locations
9.\ New head temp sensor and it measures correct via pblanders FI web page
10.\ Idle is set at 975 and it just hums perfectly.
11.\ Distributor appears to be ok and the pot moves the advance plates when vacuum is applied. Not sure about the centrifugal parts down below.
12.\ Clutch, pressure plate and all is is in good shape. Cable is adjusted perfectly
13.\ Checked grounds. (cleaned ground terminals for F.I harness.)
Here is the issue I'm having. The car takes off good in first, but you can't make it redline if you wanted to. This goes the same for any of the other gears. There is no rev limiter on the system. I can get it to rev past 6000 if I'm setting still. Just not in any gear as I upshift.
It just starts breaking up, when I punch it to the floor. I can even punch it to the floor while in second and and it just fights to get up to speed. The engine roars to life, but it labors doing so. I have to feather the gas to get it to keep the revs steady. You have to shift it fast to get the car up to speed from a light. As it breaks up in between shifts and I have to really hammer the gas. I went back to the bird site and got the instructions to check /set the TPS and that is good to go. I just do not know what the issue is.
I also notice that I can not leave it in fourth on the freeway as the engine just fights to stay at speed. I have to shift into fifth to get the car up to 70 miles per hour. And even then it will break up if I try to punch the gas any further to the floor. It is almost like I have to feather the gas pedal to get it to stay at 70 as any slight movement down on the pedal causes the car to struggle. I cannot get the car over 72 as it labors to go any farther. Something else I notice is the tach will jump up and down once in a while while keeping the gas at a steady place. I checked all behind the dash and other places looking for an electrical issue, but I do not see anything. I even ran a new wire for the ground side of the coil back to the front. No change even after doing this.
My question is. What the hell could cause it to do this?
I have run out of brain cells trying to decipher the issue.
Can anyone help?
THANKS !!!!
Steve Thacker
post Aug 24 2008, 07:33 PM
The tach jumping goes somethin like dis. Say for example that I'm cruising up the road at 2500 the tach will sometimes dip to 1900 and then bounce back to the 2500 mark.
It does this sporadically.
On the issue of fuel ( good point guys btw ). When I was building the car. I put in new aluminum fuel line from Jegs. I then tested the line and visually inspected it to make sure I had no kinks or obstructions or other issues. Tank was emptied of the old Jurassic gas and then chemically cleaned internally.
Following Rich's idea I'm going to go out an pull the tach wire from the coil and see if this thing acts the same way. As I would probably lay an egg out of pure joy if it was the issue
( if golden then I'll donate it to the club ), if not...scrambled anyone? (IMG:style_emoticons/default/wink.gif)
If all this does not prove fruitless, then I guess ripping out the Crane unit and go back to points to check that for DD's suggestion.
Steve Thacker   I need some help. Car won't rev or drive properly   Aug 24 2008, 02:00 PM
Rand   Tach jumping makes me think ignition wiring. Make ...   Aug 24 2008, 02:16 PM
orange914   i'd suspect fuel delivery, it has the earmarki...   Aug 24 2008, 02:36 PM
type47   only a guess but something to check: not getting e...   Aug 24 2008, 03:32 PM
Rand   Keep in mind, fuel delivery does not make the tach...   Aug 24 2008, 04:06 PM
orange914   Keep in mind, fuel delivery does not make the tac...   Aug 24 2008, 04:44 PM
Rand   Nah.... If electrical is strong as you're driv...   Aug 24 2008, 04:57 PM
markb   Hmmm, tach jumping. Coil connections?   Aug 24 2008, 05:02 PM
Rand   LOL. Hmm. There's a thought. :beer2:   Aug 24 2008, 05:04 PM
r_towle   I think you may need to OHM out the FI harness. Sp...   Aug 24 2008, 05:49 PM
KELTY360   I know you said the coil is new, but it could be t...   Aug 24 2008, 06:39 PM
Dave_Darling   Try going back to points to remove the Crane from ...   Aug 24 2008, 06:54 PM
r_towle   Quick test...unplug the wire for the tach. Its not...   Aug 24 2008, 07:14 PM
Steve Thacker   The tach jumping goes somethin like dis. Say for e...   Aug 24 2008, 07:33 PM
Steve Thacker   I disconnected the neg connection on the coil from...   Aug 25 2008, 05:21 PM
orange914   i know it's been poo poo'd but i still say...   Aug 25 2008, 05:43 PM
Steve Thacker   Well the good thing "and something else I for...   Aug 25 2008, 07:44 PM
Steve Thacker   I have pulled the dizzy and I'm going to make ...   Aug 26 2008, 07:53 PM
Tom   Have you checked the plugs yet? If the car won...   Aug 26 2008, 09:09 PM
Steve Thacker   Have you checked the plugs yet? If the car won...   Aug 27 2008, 12:31 PM
messix   maybe run with another known good coil, in not ano...   Aug 27 2008, 12:36 PM
Tom   One more thought, a blocked exhaust. I know it...   Aug 27 2008, 08:50 PM
Steve Thacker   I'll try both suggestions. At this point no ha...   Aug 28 2008, 06:03 AM
watsonrx13   Steve, I feel your pain and frustration. :angry: ...   Aug 28 2008, 07:04 AM
Steve Thacker   Rob, I think things are here to test us and my re...   Aug 28 2008, 08:23 PM
Steve Thacker   UPDATE: OK everything is back in. Just one lil fr...   Sep 11 2008, 07:20 PM
Dr. Roger   Maybe true but your Crane pickup was in a differen...   Sep 12 2008, 03:29 AM
Dave_Darling   Two-wire connector on top of the plenum? Temp Sen...   Sep 11 2008, 09:16 PM
Steve Thacker   Dave Thank you for the info. I'll get that cor...   Sep 12 2008, 06:17 AM
r_towle   Do you know how to static time a motor? Use a test...   Sep 12 2008, 07:29 AM
Steve Thacker   Do you know how to static time a motor? Use a tes...   Sep 12 2008, 06:51 PM
r_towle   Do you know how to static time a motor? Use a te...   Sep 12 2008, 06:56 PM
Steve Thacker   Aye Sir   Sep 12 2008, 06:56 PM
Steve Thacker   OK a update to my hell on earth... Well I made m...   Sep 15 2008, 06:27 PM
orange914   Well I made myself one of those dandy static lig...   Sep 15 2008, 10:33 PM
Steve Thacker   Well I made myself one of those dandy static li...   Sep 16 2008, 02:30 PM
Steve Thacker   UPDATE: I just pulled the dizzy out and checked t...   Sep 16 2008, 07:27 PM
Rand   Is that braided ground strap between the advance p...   Sep 16 2008, 08:17 PM
Steve Thacker   I had to make a ground strap as the braided one fe...   Sep 16 2008, 08:58 PM
Dave_Darling   They come with new points plates. Which are good ...   Sep 16 2008, 09:12 PM
Steve Thacker   :idea:   Sep 17 2008, 05:21 AM
- Lo-Fi Version Time is now: 17th July 2025 - 12:27 AM
