> uh oh my frame is a sagin! what to do?
JOE M
post Aug 19 2008, 06:30 PM
Uhhhhhh Ohhhhhhhhhh
My passenger door is sagging and I need an inexpensive way to fix it. My goal is not to have a show car but a decent driver ( without a sagging frame). I do not think it is too bad yet but the passenger door is deffinently off. I placed a jack under the front and when I raised the car the door aligned prety good. I have attached a couple of pics if it helps. It looks like the P.O did some work because the the outter portion of the long looks fairly good. Also I removed the carpet to see if that revealed anything and it looks pretty good. I can not see anything from inside the car but under there is some rust. It does not look as bad as some that I have seen but I am not an expert by any means. Any suggestions on what I could do to get by.
JOE M
post Aug 25 2008, 05:39 AM
Rich,
I did get the o-rings and started to adjust the carbs. It is running alot better but I am not there yet. I am close but it still farts on acceleration.LOL. I also went in and adjusted the shift linkage so now I can get in all 5 gears. I guess the finished door alignment will be secondary to getting the carbs adjusted correctly. The last thing that I will need is an e-brake handle and than it should pass inspection.
r_towle
post Aug 25 2008, 10:44 AM
Custom Member
QUOTE(JOE M @ Aug 25 2008, 07:39 AM) *
Rich,
OK,
So you rebuilt them, yes?
Did you set the float level? If not its easy.
Remove the top of the carb.
Hold the top plate with floats attached in a vertical position.
Set floats to have a spacing of 11mm from the top of the carb when you hold it vertical...the adjustment is the little tab that touches the needle valve.
You have to use really small needle nose pliers to bend that tab till you get the perfect measurement...
This is a very important setting and both carbs need to be the same.
Then after its back together, with no linkage, use the syncrometer to adjust each barrel to match the other barrel on the same carb by adjusting the air bypass/mixture screw.
Once you have a carb that matches, do the other carb. Its alot easier if you can get them to all match using these screws, but its not neccesary. What is neccesary is that both barrels of a single carb match exactly.
Then put the linkage on and sync the carbs.
Stop trying to adjust each barrel with the linkage in place...its opening up the butterfly valves...take the drop links off NOW...
Rich
JOE M   uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:30 PM
JOE M   RE: uh oh my frame is a sagin! what to do?   Aug 19 2008, 06:34 PM
Jeff Hail   Visual clues concern me. What I cannot see i...   Aug 19 2008, 06:56 PM
dr914@autoatlanta.com   in stock rocker clamshells are down and dir...   Aug 19 2008, 06:56 PM
JOE M   in stock rocker clamshells are down and di...   Aug 19 2008, 07:04 PM
r_towle   Where are you located in NH??? I am just south of ...   Aug 19 2008, 07:29 PM
JOE M   some one anyone please help. Do I need to remove a...   Aug 19 2008, 07:29 PM
r_towle   some one anyone please help. Do I need to remove ...   Aug 19 2008, 07:35 PM
Todd Enlund   Your longs dont look bad from the pics, but they ...   Aug 19 2008, 07:46 PM
r_towle   Your longs dont look bad from the pics, but they...   Aug 19 2008, 07:55 PM
Bartlett 914   [quote name='Todd Enlund' post='1068990' date='Au...   Aug 19 2008, 08:19 PM
Wes V   Joe; Jump on the offer that Towle has made!...   Aug 19 2008, 07:50 PM
JOE M   Rich the car is carbureated so the computer is pro...   Aug 20 2008, 05:46 AM
SirAndy   Show us a pic of the hell hole and the floor pan f...   Aug 19 2008, 07:31 PM
Vacca Rabite   I don't suppose it is something as simple as t...   Aug 19 2008, 09:03 PM
Phoenix 914-6GT   I don't suppose it is something as simple as ...   Aug 19 2008, 10:29 PM
roadster fan   I don't suppose it is something as simple as ...   Aug 20 2008, 01:01 AM
JOE M   Rich I am in Hudson N.H. I live off of RT3a just b...   Aug 20 2008, 05:43 AM
Vacca Rabite   Well, if it does turn out to be a broken backbone,...   Aug 20 2008, 07:18 AM
JOE M   Well, if it does turn out to be a broken backbone...   Aug 20 2008, 07:59 AM
r_towle   Joe only lives about ten minutes from my shop... I...   Aug 20 2008, 08:13 AM
6freak   Uhhhhhh Ohhhhhhhhhh My passenger door is sagging ...   Aug 20 2008, 08:36 AM
JOE M   Rich is the man!!! He will be stoping ...   Aug 20 2008, 10:23 AM
rjames   Rich is the man!!! He will be stoping...   Aug 20 2008, 01:12 PM
JOE M   I offered him beer ,wine, and even a rib eye steak...   Aug 20 2008, 01:16 PM
Vacca Rabite   No question - you are doing this the right way. R...   Aug 20 2008, 02:13 PM
JOE M   No question - you are doing this the right way. ...   Aug 20 2008, 06:33 PM
sww914   We also need to see the area directly above the ar...   Aug 20 2008, 06:40 PM
r_towle   bottom of long has been patched and welded Inner l...   Aug 20 2008, 07:19 PM
Vacca Rabite   bottom of long has been patched and welded Inner ...   Aug 20 2008, 07:27 PM
r_towle   when I get there I will take a look. I think we ca...   Aug 20 2008, 08:02 PM
JOE M   From the response I think it sounds prommising. He...   Aug 21 2008, 05:16 AM
r_towle   nope, I live in Dunstable and my shop cant really ...   Aug 21 2008, 08:09 AM
Cevan   nope, I live in Dunstable and my shop cant really...   Aug 21 2008, 07:39 PM
r_towle   Joe's car is fine. Looks like alot of welding ...   Aug 22 2008, 06:10 PM
SGB   :trophy::trophy::trophy::trophy::trophy::trophy::t...   Aug 22 2008, 06:54 PM
Vacca Rabite   Awesome. zach   Aug 22 2008, 09:22 PM
sww914   THAT'S what this place is all about! Cool...   Aug 22 2008, 10:02 PM
dlestep   cut holes and put yer feet through 'em   Aug 22 2008, 10:17 PM
Rand   B Sure. Please. Take it deeper and be sure. Crunch...   Aug 22 2008, 10:21 PM
JOE M   Thanks for stoping by Rich I do appreciate it. I s...   Aug 24 2008, 09:02 AM
rjames   I'm not questioning the final verdict, but I k...   Aug 24 2008, 01:03 PM
r_towle   not sure what he is talking about.. I jumped up an...   Aug 24 2008, 08:11 PM
JOE M   Rich, I did get the o-rings and started to adjust ...   Aug 25 2008, 05:39 AM
r_towle   Rich, I did get the o-rings and started to adjust...   Aug 25 2008, 10:44 AM
ericread   WOW! Kudos to Rich for performing the on-sit...   Aug 25 2008, 09:44 AM
- Lo-Fi Version Time is now: 13th July 2025 - 08:13 PM
