> Oil filter cross reference - Fram PH7325, What filters will fit my aftermarket oil tank?
Eddie914
post Jun 16 2006, 05:51 PM
Unregistered
I'm trying to find what oil filters are available for my 3.2 powered 914/6 conversion with a one-off oil tank mounted in the original battery location.
The car was converted by the previous owner and he was not able to provide any additional information.
The car came with a Fram PH7325 oil filter that my local auto parts stores do not stock any more.
CM Filters (Canton Mesa) has a cross reference than indicates that their model 25-282 is interchangable with the Fram PH7325.
The CM specifications indicate that the 25-282 has a 20mm thread, 2 5/8" O-Ring and 4 1/4" length.
The CM 25-282 also fits 91-94 911 Turbo, 82-up 944 and 78-up 928.
Any Suggestions?
Thanks
Eddie
Eddie914
post Aug 26 2008, 02:00 PM
Unregistered
Wow, great info on oil filters.
I just ordered 3 Mahle OC-142 filters for $5.44 each.
I'll let you know it works.
Just add $75 worth of Brad Penn 20W50 and the teener will be good to go (once I remove the engine to find out what jammed the alternator?).
Eddie
Eddie914   Oil filter cross reference - Fram PH7325   Jun 16 2006, 05:51 PM
mikez   Best to go to the auto parts store and look in the...   Jun 16 2006, 05:52 PM
Bleyseng   I sugget you don't cheap out using a Fram oil ...   Jun 16 2006, 05:59 PM
Eddie914   Do you think a Mann W 719/22 or a Purolator L30165...   Jun 16 2006, 06:42 PM
Cap'n Krusty   944s and 928s take different oil filters, so there...   Jun 16 2006, 07:31 PM
Eddie914   The mystery is solved. A very helpful gentleman at...   Jun 19 2006, 03:51 PM
MarkV   there is a handy cross- reference guide on the Wix...   Jun 19 2006, 04:04 PM
Eddie914   Are all oil filters created equal? What brand oil...   Jun 19 2006, 04:10 PM
mikez   Your first request was for a Fram filter for a NON...   Jun 19 2006, 04:29 PM
morgan_harwell   Eddie914, >914/6 conversion with a one-off oil...   Aug 22 2008, 10:47 AM
mikez   Just because it's cross referenced don't m...   Aug 22 2008, 11:04 AM
morgan_harwell   Aftermarket tank and uses a Fram? Was the tank d...   Aug 25 2008, 01:19 PM
BMartin914   After 20 years, ~200K miles, zero engine failures...   Aug 25 2008, 06:46 PM
effutuo101   I collapsed a WIC oil filter. I steped up to the K...   Aug 25 2008, 07:08 PM
Eddie914   I'm using a Carquest 85523 at this time. Let ...   Aug 25 2008, 07:29 PM
Eddie914   I went to the Mann site and searched for a 3.3L 19...   Aug 25 2008, 07:53 PM
Eddie914   Chris, Are you using the K&N HP-4001? Thanks...   Aug 25 2008, 08:02 PM
mikez   Frams don't have the bypass designed for the S...   Aug 25 2008, 08:13 PM
roadster fan   Everything you ever wanted to know about oil filte...   Aug 26 2008, 12:54 AM
Eddie914   Wow, great info on oil filters. I just ordered 3 ...   Aug 26 2008, 02:00 PM
morgan_harwell   I just read the 'oil filter study'. Specif...   Aug 26 2008, 02:17 PM
morgan_harwell   >I found a Purolator filter that measures corre...   Dec 6 2008, 11:47 AM
Phoenix 914-6GT   I don't understand why you don't just buy ...   Dec 6 2008, 12:06 PM
jd74914   Aftermarket tank Jon. :)   Dec 6 2008, 12:43 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:29 PM
