klikkid3 |
Member ![]() ![]() Group: Members Posts: 111 Joined: 2-July 08 From: san bernardino Member No.: 9,242 Region Association: Southern California ![]() |
So I recently get done with my front bearing project and the car was running so smooth and nice (IMG:style_emoticons/default/driving.gif) that I had that fear in the back of my mind about when it was all going to end. Well today I was coasting down mountain ave when the light changed so I down shifted into third, and it started. The starter is staying engaged with or without the key in. I pulled over and popped the lid and disconnected the negative terminal. Checked the wiring at the selenoid which looked normal, every time I reconnect the battery the starter engages and attempts to start the car. What do you all think? There is the obvious replace the starter but any other suggestions? I have a tow kit on it so I will try and get it home to take a closer look. Help!
klikkid3 |
I made sure to pull over and disconnect the battery when the problem started so hopefully I the avoided the crispy smelling starter. When I quickly touch the battery posts the starter sound normal it just wont shut off until the battery is disconnected. Your getting my hopes up with the 20min fix comment. What should I look for in the ignition after I get it home?
Lo-Fi Version | Time is now: 16th June 2024 - 04:53 AM |
