Wheel Spacers, rear tire rubbing? |
bob |
Aug 27 2008, 09:53 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
I ran a DE over the weekend and noticed the drivers side rear tire rubbed the paint off on the inner fender... what size spacer is anyone using? (if any?)
thanx! -bob |
Racer |
Aug 29 2008, 03:07 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Before you throw on some spacers, take a look at the car while its sitting on the ground. Crawl underneath and see how much room (if any) is between the tire and the fenderwell.
In theory, if there is room now, there would be room on the track. A tire doesn't flex at the top afterall, but at the bottom when its under cornering loads. If there is room now, I would be more suspect of failing bushings/ears/arms that are flexing under the grip of the tire and causing you to rub. A spacer may solve the problem of rubbing, but doesn't mean your 38YO bushings are doing there job! |
Lo-Fi Version | Time is now: 29th May 2024 - 03:39 AM |
