Taking the plunge, 1.8 liter FI Won't Stay Running |
knuckledrgr914 |
Aug 29 2008, 06:23 PM
Newbie Group: Members Posts: 46 Joined: 17-June 08 From: Meridian Member No.: 9,180 Region Association: None |
I am a new 914 owner and have just started trying to get it road worthy. It is a '74, 1.8 liter, and fuel injected. Now for the noobie question...
After running the car around the neighborhood, I came home with a fuel leak. I found one of the hoses, leading to what I assume is one of the injectors, was split open. I replaced the hose which stopped the gas leak. Now comes the problem... My car now fires, runs for approximately 40- 50 seconds, and then quits. It does not matter if it is just idling, or if I am giving it some juice... It just quits. I turn the key off, turn it back on and it will fire again after a couple revolutions! Any idea why changing out the bad fuel line would cause this behavior? As you can tell, I am just learning the mechanics of the 914 so be kind and send lots of pictures (of how to resolve the problem that is (IMG:style_emoticons/default/ohmy.gif)) Thanks in advance, Brad |
Spoke |
Aug 29 2008, 09:15 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Sometimes vacuum leaks can be found by spraying carb cleaner on suspected parts. If the engine changes speed when an item is doused with cleaner, then you've located a possible leak.
Lo-Fi Version | Time is now: 3rd June 2024 - 01:56 AM |
