Project Pics, Current State of the 6r |
RON S. |
Jan 9 2004, 08:42 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Heres some pics of the 6r and how it comin along.
1st one is front+ center,getty hood,glass bumper+ valance.gt type pins. Attached image(s) |
RON S. |
Jan 9 2004, 02:00 PM
QUOTE(Air_Cooled_Nut @ Jan 9 2004, 11:21 AM) How hard (or easy) is it to get to that fuel pump? Loosen the oil line,it'll drop out of the way.The frame you see is stainless,with a Lexan window behind it.Your seeing the pump from behind a inspection window.Pump is mounted in a foam cushioned housing.I can remove either pump in about 15 mins. flat. Why brass oil lines? Are they lighter than hose? Is there a safety benefit over hose? I wanted to copy the gt look.Also,brass is a natural heat sink.So there is some cooling benefit to & from the cooler.It also is not a hose,so it can't wear out and leak. The lines are 1"O.D. w/a .032 wall.I got them from McMaster Carr.They come in 6'lengths for 22.00 per length.Thats 3-1/2 dollars a foot,give or take.Around here,-16 braided hose is running 12.00 a foot. Ron Attached |
Lo-Fi Version | Time is now: 9th June 2024 - 12:46 PM |
