nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
how do you remove the fan hub to get to the front seal? the 914 manual says i need a special tool. i don,t have one, i don,t even know what kid of tool it is or why itis special. any alternatives? (IMG:style_emoticons/default/sad.gif)
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
my alternative was to get 2 steel plates about 1/8th inch thick (or thin enough to fit between the hub and the case) and kinda didn't matter the dimensions but there was stock about 1.5"wide and about 4-5" long. when you remove the fan there are 3 long, i think 8mm bolts. to remove the hub, take the 2 pieces of stock and one should fit under a screw hole in the hub and the other should fit under the other 2 screw holes in the hub. screw in the bolts into the holes in the hub until they touch the stock. the stock is under the hub, over the case: between the hub and the case. gently screw in the bolts to put force outward on the hub, probably alternating tightening each bolt a little at a time. the factory tool is a u-shaped metal piece that esentially does the same thing.
nycchef |
my alternative was to get 2 steel plates about 1/8th inch thick (or thin enough to fit between the hub and the case) and kinda didn't matter the dimensions but there was stock about 1.5"wide and about 4-5" long. when you remove the fan there are 3 long, i think 8mm bolts. to remove the hub, take the 2 pieces of stock and one should fit under a screw hole in the hub and the other should fit under the other 2 screw holes in the hub. screw in the bolts into the holes in the hub until they touch the stock. the stock is under the hub, over the case: between the hub and the case. gently screw in the bolts to put force outward on the hub, probably alternating tightening each bolt a little at a time. the factory tool is a u-shaped metal piece that esentially does the same thing. let me see if i inderstand this. the metal plates are a backstop , as you screw in the bolts the hub will push forward? |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
my alternative was to get 2 steel plates about 1/8th inch thick (or thin enough to fit between the hub and the case) and kinda didn't matter the dimensions but there was stock about 1.5"wide and about 4-5" long. when you remove the fan there are 3 long, i think 8mm bolts. to remove the hub, take the 2 pieces of stock and one should fit under a screw hole in the hub and the other should fit under the other 2 screw holes in the hub. screw in the bolts into the holes in the hub until they touch the stock. the stock is under the hub, over the case: between the hub and the case. gently screw in the bolts to put force outward on the hub, probably alternating tightening each bolt a little at a time. the factory tool is a u-shaped metal piece that esentially does the same thing. let me see if i inderstand this. the metal plates are a backstop , as you screw in the bolts the hub will push forward? Yes, exactly zactly breath... Rich |
nycchef |
[/quote] Yes, exactly zactly breath... Rich [/quote] so providing i pull this off, literally, should i assume that after installing the washer and the new seal the hub will just slide baqck on? |
Lo-Fi Version | Time is now: 17th June 2024 - 01:28 AM |
