nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
how do you remove the fan hub to get to the front seal? the 914 manual says i need a special tool. i don,t have one, i don,t even know what kid of tool it is or why itis special. any alternatives? (IMG:style_emoticons/default/sad.gif)
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,466 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
make sure you remove the big washer directly behind the bolt before you try pulling it.
Also, get some PB Blaster in a spray bottle and spray it down really good to make the job a little easier. They are under a lot of pressure. The first one I removed literally shot across the room when it finally popped. Make sure that the bolt is threaded in all the way or it will bend. Put the "point" of the puller on the bolt. If you end up bending the bolt, let me know. McMaster sells them in 5 packs. I have 4 of them left over. :-) Zach |
Lo-Fi Version | Time is now: 16th June 2024 - 10:58 PM |
