More Pics Needed, Rear Camber Shims |
7275914911 |
Sep 15 2008, 09:32 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I have searched and found discussion on above topic but can't find any pics. The exploded Katalog pic is no real help and I don't believe I have any shims in at all or at least I don't see them.
Thx in advance for guidance JKP |
r_towle |
Sep 15 2008, 09:37 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
look up Engman here and go to his site.
He sells them. They are lazer cut replica shims. Rich |
7275914911 |
Sep 15 2008, 09:55 PM
SirAndy |
Sep 15 2008, 10:41 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I need to see exactly where to putum.. Adding shims will dial out negative camber. Are you sure you have too much negative camber ??? (IMG:style_emoticons/default/idea.gif) Andy |
7275914911 |
Sep 15 2008, 11:18 PM
I need to see exactly where to putum.. Adding shims will dial out negative camber. Are you sure you have too much negative camber ??? (IMG:style_emoticons/default/idea.gif) Andy Andy, It is setup great for AX/Track with rear at roughly 30 degree angles but it is way to much for road trips or round town driving. Just purchased new rubber for those puposes and want it to last. Also thx Rich for the graphic description. Should not need a pic with that. jkp |
jcd914 |
Sep 16 2008, 12:57 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
QUOTE at roughly 30 degree angles 30 degrees is not possible without bending something. (IMG:style_emoticons/default/sad.gif) Are you having trouble with tire wear? OK someone will probably disagree with me here but that is OK. -1 degree 30 minutes (-1 1/2 degrees) rear camber will not really cause a lot of tire wear if the toe is set conservatively, maybe a 1/16" toe in on each side. It is the combination of a lot of camber and too much toe that eats up the rear tire (fronts for that matter). I have set a lot of Porsche's up with close to -2 degrees of camber with big wear issues. If all you are going to do is drive straight down the road then you don't need any camber but if you want to corner occasionally it is worth the extra wear. Jim |
7275914911 |
Sep 16 2008, 06:14 AM
QUOTE at roughly 30 degree angles 30 degrees is not possible without bending something. (IMG:style_emoticons/default/sad.gif) Are you having trouble with tire wear? OK someone will probably disagree with me here but that is OK. -1 degree 30 minutes (-1 1/2 degrees) rear camber will not really cause a lot of tire wear if the toe is set conservatively, maybe a 1/16" toe in on each side. It is the combination of a lot of camber and too much toe that eats up the rear tire (fronts for that matter). I have set a lot of Porsche's up with close to -2 degrees of camber with big wear issues. If all you are going to do is drive straight down the road then you don't need any camber but if you want to corner occasionally it is worth the extra wear. Jim 30 might be a bit much. It was a guess. They are very aggressive looking tho. I like the setup for AX but tire wear is a concern on the road. It is not my DD but it is driven a lot. Thx for the good info Jim jkp |
Lo-Fi Version | Time is now: 15th June 2024 - 02:59 PM |
