I want to drive my 914 but it dont work!, I need serious help. |
JOE M |
Sep 15 2008, 06:39 PM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I cant seem to get my carbs synced up correctly. I have tried everything but no luck. Let me start by saying I have Weber Redline IDF 40`S. They are the old style with the bigger pumps if that matters. I forget what the the jet size is but I done think thats my problem. I had Rich take a look a month ago or so and if I remember right he said that the size looked about right. I have zero experience with carbs so I am totally in the dark. I did buy a new gasket set and it came with new pumps and some o-rings. It also came with a new float valve. Where I am now is that the car starts right up and idles the balls. It sounds great but as soon as I put it in gear and give a little gas is bogs down. I have the air mixture screws all the way in and the spring loaded screws (not the idle adjust) about 2 turns out.I know that all 4 cylinders are about the same because I have a syncrometer and they all measure about 6~7 on the flow meter. I remember Rich advising me to make th adjustments with the linkage off so thats what I did. All I want is to be able to drive this thing around the block with out it farting and burping. The only thing that should cause farting and burping is beer. If anyone has any thing to offer please help.I am a desperate man and ready to get rid of this thing. Serious I will never get rid of it but I do want to understand better about how to get it to run correctly.I will deal with all the other little things later but my main goal is to get it on the street and have some fun.
JOE M |
Sep 16 2008, 09:57 AM
I have the air bypass all the way in. That is what the setup procedure said to do at Weber Redline website. See the highlighted area below. I will need to verify the float position because I think it is off. Rich is coming over sometime tonight so I am in good hands. I think his experience will help determine what is going on.The other problem that I have is that the mixture screws ( spring loaded) do not appear to be correct. There were no o-rings and the cup washer seems way to big.This is probably causing some issue also. I called weber and they do not have any specs on the cup washer so I have no way of knowing if it is correct but it seems way to big from what I see. I will wait for Rich and get his opinion. I have some orings that fit but because the hole diameter on the washer is so big the o-rings slip through it.Below is also a pic of the mixture screw with the swivel washer over it. This is the washer that was on all 4 mixture screws when I got the car.
r_towle |
Sep 16 2008, 06:37 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have the air bypass all the way in. That is what the setup procedure said to do at Weber Redline website. See the highlighted area below. I will need to verify the float position because I think it is off. Rich is coming over sometime tonight so I am in good hands. I think his experience will help determine what is going on.The other problem that I have is that the mixture screws ( spring loaded) do not appear to be correct. There were no o-rings and the cup washer seems way to big.This is probably causing some issue also. I called weber and they do not have any specs on the cup washer so I have no way of knowing if it is correct but it seems way to big from what I see. I will wait for Rich and get his opinion. I have some orings that fit but because the hole diameter on the washer is so big the o-rings slip through it.Below is also a pic of the mixture screw with the swivel washer over it. This is the washer that was on all 4 mixture screws when I got the car. PIC1.bmp ( 291.21k ) Number of downloads: 52 Oops, forgot. I spent all day roofing my FIL house...I am beat tired. Can we do this Wed night, same time? Rich |
JOE M |
Sep 16 2008, 06:40 PM
I have the air bypass all the way in. That is what the setup procedure said to do at Weber Redline website. See the highlighted area below. I will need to verify the float position because I think it is off. Rich is coming over sometime tonight so I am in good hands. I think his experience will help determine what is going on.The other problem that I have is that the mixture screws ( spring loaded) do not appear to be correct. There were no o-rings and the cup washer seems way to big.This is probably causing some issue also. I called weber and they do not have any specs on the cup washer so I have no way of knowing if it is correct but it seems way to big from what I see. I will wait for Rich and get his opinion. I have some orings that fit but because the hole diameter on the washer is so big the o-rings slip through it.Below is also a pic of the mixture screw with the swivel washer over it. This is the washer that was on all 4 mixture screws when I got the car. PIC1.bmp ( 291.21k ) Number of downloads: 52 Oops, forgot. I spent all day roofing my FIL house...I am beat tired. Can we do this Wed night, same time? Rich That works for me but I will not be home untill 6. Is that o.k with you? |
Lo-Fi Version | Time is now: 9th June 2024 - 01:42 PM |
