> Carbs VS FI, Which is better?
Carbs VS FI
Which is better?
Carbs because... [ 35 ] ** [27.34%]
FI because... [ 93 ] ** [72.66%]
Total Votes: 128
Guests cannot vote
dbgriffith75
post Sep 16 2008, 04:08 PM
TheGrif
So basically I'm just curious here on who's opinion is what and why. I might have seen a similar post a while back but I don't remember for sure.
My personal opinion is carbs. I don't know what a new injector for a 914 is going for but generally speaking carb kits are cheaper than new injectors. Plus, I like trying to fine tune carbs- if one is set right the engine can be extremely efficient. My teener is set up for carbs and I plan to leave it that way.
EyeTrip
post Sep 16 2008, 06:52 PM
Love the sound of dual webers
Once setup, carbs are more reliable than the 40yr 1st gen injection
Very clean install over injection
Now, I would like to megasqirt a 1911. I think that would be fun.
Bleyseng
post Sep 16 2008, 07:25 PM
Aircooled Baby!
QUOTE(EyeTrip @ Sep 16 2008, 05:52 PM) *
Love that sound? cuz thats all you can hear carbs are soo loud. I have a CD player and like to listen to music driving not that sucking sound.
Once setup? yep, and then they go out of sync again and again.
Clean? Stock FI is really clean and reliable as its still going strong.
Low end power? Bow to FI as it has better low end power.
Tuneable? Bolt on the stock parts and its tuned or if you have a 2056 w/ mild cam adjust the MPS and forget about it.
Plus you can get 30mpg with Djet / Ljet and FI has built in altitude adjustment for those up into the mountain road days.
In 1999 I went back to djet pulling the 40 dells and have never looked back, never been broke down by the side of the road either with djet. Carbs? several times...and they are sitting on the shelf gathering dust...
EyeTrip
post Sep 17 2008, 03:39 AM
[quote name='Bleyseng' date='Sep 16 2008, 06:25 PM' post='1080296']
[quote name='EyeTrip' post='1080266' date='Sep 16 2008, 05:52 PM']
[/quote]
[quote]Love that sound? cuz thats all you can hear carbs are soo loud. I have a CD player and like to listen to music driving not that sucking sound[/quote]
Sissy, A real car will talk to you and make you feel the road. I have a cd player too, but most of the time I find it off so I can enjoy the ride
[quote]Once setup? yep, and then they go out of sync again and again.[/quote]
The only resons I find them out of sync is bad linkage or vacuum issuse.
[quote]Clean? Stock FI is really clean and reliable as its still going strong.[/quote]
Out of the box carbs will have issues but a tuned set of webers are very clean and more relaible dont be fooled
[quote]Low end power? Bow to FI as it has better low end power.[/quote]
HAHA low end? If you want carbs to performs that way you can.... but I prefer the whole range.
[quote]Tuneable? Bolt on the stock parts and its tuned or if you have a 2056 w/ mild cam adjust the MPS and forget about it.[/quote]
I think thats cool. But your still in the realm of carbs.
[quote]Plus you can get 30mpg with Djet / Ljet and FI has built in altitude adjustment for those up into the mountain road days.[/quote]
Thats great, I have never felt much difference going up Donner summit @ 7200 ft other than running out of air.
If you want the best you need to go for a modern FI, not a 40yr old fi. The new ones are so much more accurate and stable (not to mencheon the parts cost and availibilty) But don't discard the carbs because you don't understand them.
dbgriffith75   Carbs VS FI   Sep 16 2008, 04:08 PM
melnyk   So basically I'm just curious here on who...   Sep 16 2008, 04:43 PM
BarberDave   :trophy: I have Carbs, i like them. How ever ...   Sep 16 2008, 04:57 PM
Lavanaut   Try a search... http://www.914world.com/bbs2/inde...   Sep 16 2008, 05:03 PM
jasons   I :wub: DJET! When its properly set up, it...   Sep 16 2008, 05:08 PM
jd74914   My L-Jet car runs great. :D On a side note, I...   Sep 16 2008, 05:11 PM
vsg914   Jeez, here we go again.   Sep 16 2008, 05:57 PM
So.Cal.914   Why?..Cause. :)   Sep 16 2008, 06:01 PM
scotty b   Why?..Cause. :) God I hope that's just d...   Sep 16 2008, 07:30 PM
type47   FI because it was factory installed FI because it ...   Sep 16 2008, 06:07 PM
toon1   FI is better unless you like carbs, then carbs. ar...   Sep 16 2008, 06:11 PM
So.Cal.914   Carbs because they sound Great. :) Carbs because...   Sep 16 2008, 06:14 PM
Todd Enlund   I voted FI because it is infinitely more tunable. ...   Sep 16 2008, 06:28 PM
r_towle   I would say this. Preface...I have a Djet and and ...   Sep 16 2008, 06:34 PM
EyeTrip   Modern FI would be my choice, something with an ...   Sep 16 2008, 06:54 PM
EyeTrip   Love the sound of dual webers Once setup, carbs ar...   Sep 16 2008, 06:52 PM
Bleyseng   Love the sound of dual webers Once setup, carbs a...   Sep 16 2008, 07:25 PM
vsg914   Love the sound of dual webers Once setup, carbs ...   Sep 16 2008, 08:20 PM
vsg914   Edit: delete accidental double post. Damn fat fing...   Sep 16 2008, 08:21 PM
EyeTrip   [quote name='EyeTrip' post='1080266...   Sep 17 2008, 03:39 AM
dbgriffith75   the TPS and MPS are NLA! the TPS and MPS are...   Sep 16 2008, 06:53 PM
azbill   FI is the way to go. I'm running the Emerald M...   Sep 16 2008, 07:00 PM
dflesburg   We have two 1970 cars both with 2.0 motors, one wi...   Sep 16 2008, 08:27 PM
So.Cal.914   That should be spelt BLOW With the FI that came ...   Sep 16 2008, 08:35 PM
vsg914   That should be spelt BLOW With the FI that came...   Sep 16 2008, 08:53 PM
Bleyseng   That should be spelt BLOW With the FI that cam...   Sep 16 2008, 10:42 PM
Dave_Darling   Which is better? Yes--yes they are. Really, what...   Sep 16 2008, 09:09 PM
So.Cal.914   With what I put into that FI it should have levita...   Sep 16 2008, 11:30 PM
Justinp71   I like carbs because I'm mechanical... but whe...   Sep 16 2008, 11:53 PM
Rand   My FI starts promptly, idles flawlessly, and runs ...   Sep 16 2008, 11:54 PM
Bleyseng   I'll be running carbs on the next engine, 2.4L...   Sep 17 2008, 08:47 AM
Mark Henry   I voted FI, but d and L-jet sucks....SDS baby I...   Sep 17 2008, 01:44 PM
Cevan   I voted FI, but d and L-jet sucks....SDS baby I...   Sep 17 2008, 02:27 PM
DBCooper   If you're going to compare then you need to co...   Sep 17 2008, 04:13 PM
SirAndy   Carbs VS FI, Which is better? No ...   Sep 17 2008, 07:06 PM
SGB   I like carbs because people talk about "good ...   Sep 17 2008, 07:45 PM
So.Cal.914   For all of you that think injection is the best, I...   Sep 17 2008, 08:27 PM
749142   fi becuase, better gas mpg its original, and setu...   Sep 17 2008, 08:32 PM
DBCooper   Pro Systems, you mean the drag-racing carburetor m...   Sep 17 2008, 08:58 PM
Spoke   I like FI because I could sell my used dual Weber ...   Sep 17 2008, 09:57 PM
Mark Henry   Now if your happy with a stock 80/95hp L/D-jet eng...   Sep 17 2008, 10:01 PM
So.Cal.914   Now if your happy with a stock 80/95hp L/D-jet en...   Sep 18 2008, 06:01 PM
DBCooper   I do have a preference like alot of others here, ...   Sep 18 2008, 07:09 PM
DBCooper   That's why I said a stock engine, that's w...   Sep 17 2008, 10:36 PM
So.Cal.914   I drive mine FT quite often, I built my engine t...   Sep 17 2008, 10:58 PM
DBCooper   Great, like everything else on your car, do what y...   Sep 17 2008, 11:36 PM
LarryR   I think you needed a 3rd category aftermarket fuel...   Sep 17 2008, 11:39 PM
dw914er   I voted FI. It workes great, and is pretty reliabl...   Sep 17 2008, 11:44 PM
vsg914   See? One more useless thread about FI vs carbs. To...   Sep 18 2008, 08:00 AM
Mark Henry   See? One more useless thread about FI vs carbs. T...   Sep 18 2008, 08:18 AM
DBCooper   Most peeps who hate carb's never had a clue o...   Sep 18 2008, 09:15 AM
carcam   I'm new and like this thread. What's PMO?...   Sep 18 2008, 10:50 AM
DBCooper   They're modern upscale carburetors: http://ww...   Sep 18 2008, 03:56 PM
J P Stein   As the Canuck says, PEFI makes more power (& t...   Sep 18 2008, 06:34 PM
nsr-jamie   Didn't the Euro 1.8 models come with carbs ins...   Nov 25 2010, 05:54 AM
Bleyseng   Didn't the Euro 1.8 models come with carbs in...   Nov 26 2010, 06:16 AM
underthetire   I voted FI, not stock, but I love to diagnose thro...   Nov 25 2010, 10:26 AM
JmuRiz   FI is the best, but I'm thinking more EFI...bu...   Nov 25 2010, 08:50 PM
speed metal army   I voted FI,Its predictable,and performs well.I als...   Nov 25 2010, 09:12 PM
914 shifter   up to 2056 original d-jet. :shades2: bigger displa...   Nov 26 2010, 05:57 AM
benalishhero   I've had three different set-ups on my stock 2...   Nov 28 2010, 08:03 AM
J P Stein   Dueling carbs is a very common occurance around he...   Nov 28 2010, 08:29 AM
ME733   I voted for Carburators...........here,s why....Th...   Nov 28 2010, 09:00 AM
Jake Raby   I provide engines with stock FI, programmable FI a...   Nov 28 2010, 10:08 AM
Gint   Yikes... Just when you thought that the only thin...   Nov 28 2010, 10:59 AM
hashagen7   I will gladly trade this for your carbs.   Nov 28 2010, 03:17 PM
Drums66   I will gladly trade this for your carbs. .....N...   Nov 29 2010, 05:26 PM
chrisg   Maybe slightly off topic, but has anybody had prob...   Nov 28 2010, 09:12 PM
'73-914kid   I was having the same problem for a while.. It...   Nov 28 2010, 09:20 PM
tradisrad   I like my d-jet set up. No cold start issues, star...   Nov 29 2010, 09:56 AM
benalishhero   Chrisg, does CA have E10? We run it up in Maine. N...   Nov 29 2010, 10:10 AM
Dave_Darling   Chrisg, does CA have E10? Evidently we do, as o...   Jun 5 2011, 12:14 AM
ewdysar   Carbs are inherently better. That's why all m...   Jun 5 2011, 02:31 AM
ConeDodger   I voted for fuel injection... There is nothing w...   Jun 5 2011, 08:04 AM
SLITS   And the debate goes on and on and on and on .... ...   Jun 5 2011, 09:31 AM
patssle   And I do! I get 14 mpg in city driving with ...   Jun 5 2011, 09:46 AM
76-914   FI baby. Why? ...   Jun 5 2011, 10:12 AM
SirAndy   Carbs VS FI, Which is better? Yes ... :D   Jun 5 2011, 09:54 PM
al weidman   I'm an old guy and I would say it depends on e...   Jun 6 2011, 10:07 AM
Elliot Cannon   I'm an old guy and I would say it depends on ...   Jun 6 2011, 02:15 PM
Bleyseng   Well, after buying my 76 914 2.0l with Dell 40...   Jun 6 2011, 12:13 PM
CrashDown   Carbs are inherently better. That's why all ...   Jun 7 2011, 07:49 AM
Dave_Darling   I have Redline 40's on my 914. i commute 50 m...   Jun 8 2011, 12:21 AM
ewdysar   Carbs are inherently better. That's why all...   Jun 8 2011, 12:50 AM
Bleyseng   $1000 to rebuild at YOUR COST at your work? W...   Jun 7 2011, 09:57 AM
jzdu   If anyone is scrapping their D-jet, I need the aux...   Jun 8 2011, 04:26 PM
PRS914-6   Well, the poll only asks FI vs. carbs so general q...   Aug 7 2011, 09:18 PM
GeorgeRud   :agree: though I love the look of my Webers, PRS...   Sep 6 2011, 07:51 AM
stugray   Just curious then: Why was the 914-6 GT racing car...   Sep 6 2011, 12:32 PM
Dave_Darling   Just curious then: Why was the 914-6 GT racing ca...   Feb 15 2012, 04:55 PM
914_teener   Just curious then: Why was the 914-6 GT racing c...   Feb 15 2012, 09:09 PM
FourBlades   EFI for a daily driver because of its sealed fuel ...   Sep 6 2011, 03:09 PM
Robert21   It will be eight years with my 914 2.0 Had t...   Feb 15 2012, 10:50 AM
gil914   F.I. any day. My WRX has fully programmable stock ...   Feb 15 2012, 12:58 PM
reharvey   [quote name='gil914' date='Feb 15 2012...   Feb 15 2012, 03:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
