dbgriffith75
Sep 16 2008, 04:08 PM
So basically I'm just curious here on who's opinion is what and why. I might have seen a similar post a while back but I don't remember for sure.
My personal opinion is carbs. I don't know what a new injector for a 914 is going for but generally speaking carb kits are cheaper than new injectors. Plus, I like trying to fine tune carbs- if one is set right the engine can be extremely efficient. My teener is set up for carbs and I plan to leave it that way.
melnyk
Sep 16 2008, 04:43 PM
QUOTE(dbgriffith75 @ Sep 16 2008, 06:08 PM)
how efficient? i think i have a blown mps and i personally dont like over complicated devices. i would like 25-27 mpg. id so i think im just going to go that route if i can get this mileage. my car isnt a DD and a carb is way easier to diagnose for me.
BarberDave
Sep 16 2008, 04:57 PM
I have Carbs, i like them. How ever I voted for F.I.. Never haveing F.I. I would
like to play with that. More power, adjustability , and original. I 'm nut's i
guess!!!! Dave
Lavanaut
Sep 16 2008, 05:03 PM
jasons
Sep 16 2008, 05:08 PM
I
DJET! When its properly set up, it works great.
Outside of a stock motor though, I'll take Dellortos.
jd74914
Sep 16 2008, 05:11 PM
My L-Jet car runs great.
On a side note, I'm too young to have tons of experience with carbs, so any warmed up thing I build will have PEFI on it.
TheCabinetmaker
Sep 16 2008, 05:57 PM
Jeez, here we go again.
So.Cal.914
Sep 16 2008, 06:01 PM
type47
Sep 16 2008, 06:07 PM
FI because it was factory installed
FI because it is more modern than carbs
FI because it's more efficient
IMHO
toon1
Sep 16 2008, 06:11 PM
FI is better unless you like carbs, then carbs. are better
Personally, I'm on the no carb. diet.
Try the search from the link's above, this discussion has been beat to death.
So.Cal.914
Sep 16 2008, 06:14 PM
Carbs because they sound Great.
Carbs because it gives better low end.
Aaaaaaand, Carbs because the POS FI kept breaking down and leaving me stranded all over Hells Acre.
IMHO
Todd Enlund
Sep 16 2008, 06:28 PM
I voted FI because it is infinitely more tunable. You didn't specify stock FI or aftermarket... FI offers better MPG, better power, better driveability, all in the same tune. Carbs you pretty much need to decided how you want the car to run, and you'll sacrifice somewhat in other areas.
But, I plan on using 44 IDFs on my 2258. In my case, they will cost about 10% of what a comparable FI system would cost me. Maybe somewhere down the road, I will switch to FI, but it will be pretty low on my priority list.
r_towle
Sep 16 2008, 06:34 PM
I would say this.
Preface...I have a Djet and and Ljet car.
For simple drive and go, the stock FI is fine, once you troubleshoot it and replace any worn parts.
Unfortunately the TPS and MPS are NLA...say that three times fast.
The can be tuned and can be modified for larger motors, but you really need to have your wits about you to make it work...it simple, but fubar if you change the wrong thing in the motor.
Carbs are way more flexible, but you suffer from poor mileage and they run like crap for the first 10 minutes.
Modern FI would be my choice, something with an O2 sensor and a feedback loop to monitor the system..
It really amazes me how much HP these modern cars get from the modern FI system...its just much better technology overall.
Rich
EyeTrip
Sep 16 2008, 06:52 PM
Love the sound of dual webers
Once setup, carbs are more reliable than the 40yr 1st gen injection
Very clean install over injection
Now, I would like to megasqirt a 1911. I think that would be fun.
dbgriffith75
Sep 16 2008, 06:53 PM
the TPS and MPS are NLA!
mwa ha ha... I accept your challenge and await your rebuttle!
EyeTrip
Sep 16 2008, 06:54 PM
QUOTE(r_towle @ Sep 16 2008, 05:34 PM)
Rich
I agree 100%
azbill
Sep 16 2008, 07:00 PM
FI is the way to go. I'm running the Emerald M3D ECU with Jennvey throttle bodies other then the noise form the Jennveys the system is great. It took awhile to get ECU programmed but once it was set it is fantastic.
Bleyseng
Sep 16 2008, 07:25 PM
QUOTE(EyeTrip @ Sep 16 2008, 05:52 PM)
Love that sound? cuz thats all you can hear carbs are soo loud. I have a CD player and like to listen to music driving not that sucking sound.
Once setup? yep, and then they go out of sync again and again.
Clean? Stock FI is really clean and reliable as its still going strong.
Low end power? Bow to FI as it has better low end power.
Tuneable? Bolt on the stock parts and its tuned or if you have a 2056 w/ mild cam adjust the MPS and forget about it.
Plus you can get 30mpg with Djet / Ljet and FI has built in altitude adjustment for those up into the mountain road days.
In 1999 I went back to djet pulling the 40 dells and have never looked back, never been broke down by the side of the road either with djet. Carbs? several times...and they are sitting on the shelf gathering dust...
scotty b
Sep 16 2008, 07:30 PM
QUOTE(So.Cal.914 @ Sep 16 2008, 04:01 PM)
God I hope that's just drool on that filter lid
TheCabinetmaker
Sep 16 2008, 08:20 PM
QUOTE(Bleyseng @ Sep 16 2008, 08:25 PM)
100%
TheCabinetmaker
Sep 16 2008, 08:21 PM
Edit: delete accidental double post. Damn fat fingers.
dflesburg
Sep 16 2008, 08:27 PM
We have two 1970 cars both with 2.0 motors, one with stock FI and one with dual two barrel dells. Wont have both running togeather for about four years. Will let you know.
So.Cal.914
Sep 16 2008, 08:35 PM
That should be spelt BLOW
With the FI that came with the car the low end sucked. On a slow corner I would have to go for first. With the Webers I only need to go for first when I stop. The FI also had a 'Lag' at take off.
But the fuel milege was great, LA to San diego on a half a tank.
TheCabinetmaker
Sep 16 2008, 08:53 PM
QUOTE(So.Cal.914 @ Sep 16 2008, 09:35 PM)
Your FI was seriously out of tune.
Dave_Darling
Sep 16 2008, 09:09 PM
Which is better?
Yes--yes they are.
Really, what do you know? If you're happy synch'ing carbs, blowing out jets, and tweaking mixture screws, carbs are better. If you're happy just driving until something decides not to work, then troubleshooting that, then go with EFI.
Carbs seem to have the potential to make the most power; they don't really care about cams, for instance. EFI has the potential for far better driveability.
...Just as long as you don't go with the crappy single-Weber setup, either is cool.
--DD
Bleyseng
Sep 16 2008, 10:42 PM
QUOTE(vsg914 @ Sep 16 2008, 07:53 PM)
Vacuum leaks or majorly out of tune as FI has better throttle response than carbs
So.Cal.914
Sep 16 2008, 11:30 PM
With what I put into that FI it should have levitated, When it worked it worked fine
other than being gutless at low end. Other than cleaning the jets once and awhile
and an occasional synchronization carbs have never let me down.
Carbs may suck but that FI blows. At least mine did...And a whole shit load I have
read about here (and other sites) over the years.
Justinp71
Sep 16 2008, 11:53 PM
I like carbs because I'm mechanical... but when I had fi my car didn't smell...
I would say carbs are a good replacement for any 30 year old injection system that isn't running well...
Rand
Sep 16 2008, 11:54 PM
My FI starts promptly, idles flawlessly, and runs as strong as possible at all elevations and temperatures.
If I was to build a 2270 then I would need a different system. I could go with dual Dells and that would be great. But I would sacrifice some of the benefits listed above. Or I could go with a modern FI system like SDS and have the best of all worlds.
Depends on the engine.
In general terms (across the board, not just 914), assess which modern and competitive cars run FI vs carbs and why.
EyeTrip
Sep 17 2008, 03:39 AM
[quote name='Bleyseng' date='Sep 16 2008, 06:25 PM' post='1080296']
[quote name='EyeTrip' post='1080266' date='Sep 16 2008, 05:52 PM']
[/quote]
[quote]Love that sound? cuz thats all you can hear carbs are soo loud. I have a CD player and like to listen to music driving not that sucking sound[/quote]
Sissy, A real car will talk to you and make you feel the road. I have a cd player too, but most of the time I find it off so I can enjoy the ride
[quote]Once setup? yep, and then they go out of sync again and again.[/quote]
The only resons I find them out of sync is bad linkage or vacuum issuse.
[quote]Clean? Stock FI is really clean and reliable as its still going strong.[/quote]
Out of the box carbs will have issues but a tuned set of webers are very clean and more relaible dont be fooled
[quote]Low end power? Bow to FI as it has better low end power.[/quote]
HAHA low end? If you want carbs to performs that way you can.... but I prefer the whole range.
[quote]Tuneable? Bolt on the stock parts and its tuned or if you have a 2056 w/ mild cam adjust the MPS and forget about it.[/quote]
I think thats cool. But your still in the realm of carbs.
[quote]Plus you can get 30mpg with Djet / Ljet and FI has built in altitude adjustment for those up into the mountain road days.[/quote]
Thats great, I have never felt much difference going up Donner summit @ 7200 ft other than running out of air.
If you want the best you need to go for a modern FI, not a 40yr old fi. The new ones are so much more accurate and stable (not to mencheon the parts cost and availibilty) But don't discard the carbs because you don't understand them.
Bleyseng
Sep 17 2008, 08:47 AM
I'll be running carbs on the next engine, 2.4L till I get a FI system.
Mark Henry
Sep 17 2008, 01:44 PM
I voted FI, but d and L-jet sucks....SDS baby
I've messed with weber's for years and it sucks compared to PEFI (P as in programmable) The only thing carbs beats PEFI on is the price.
But then I think anything stock sucks
Cevan
Sep 17 2008, 02:27 PM
QUOTE(Mark Henry @ Sep 17 2008, 03:44 PM)
For stock motors, I'd go stock FI based on my own experiences. I've put about 4500 miles on my L-Jet 1.8 in the last year and it doesn't suck. Starts every time, warms up great, doesn't stall, doesn't stumble, runs the same in hot or cold weather, humid or dry. I'd rather spend the $$$ an SDS system would cost on tires, suspension and gas.
DBCooper
Sep 17 2008, 04:13 PM
If you're going to compare then you need to compare apples to apples. The ONLY people who prefer carbs to fuel injection are people who didn't have correctly adjusted fuel injection. On a stock engine there is no way that correctly adjusted fuel injection doesn't outperform correctly adjusted carburetors in any way you compare them, at high altitude or sea level; hot or cold; idling or acceleration; power, mileage or tractability. No how, no where, no way. Not possible in theory, nor in practice.
The only advantage carburetors have is the vroom vroom sound.
Thinking about carburetors? Fix your fuel injection. Simple enough, and problem solved.
Sep 17 2008, 07:06 PM
QUOTE(dbgriffith75 @ Sep 16 2008, 02:08 PM)
Carbs VS FI, Which is better?
No ...
SGB
Sep 17 2008, 07:45 PM
I like carbs because people talk about "good carbs" and sometimes "bad carbs" but NOBODY wants to talk about "good fi". Maybe "good Hi-Fi" or maybe "Sci-Fi". But not "Eff-I". Although when I asked someone at the beverage store, I was told "Eff-U" but I think they were confused. Nope. I'm going with carbs.
Besides, mine are SHINEY.
So.Cal.914
Sep 17 2008, 08:27 PM
For all of you that think injection is the best, I give you this. It is long but very well written by a expert from Pro Systems who has worked heavily in both areas.
Carburetion Vs. Injection
One of the most often asked questions is why do carburetors make more power then EFI and why do the car manufacturers use EFI if carburetors make more power?
A few years ago we used some contacts at General Motors to verify some simple facts from some dyno data we had received from a head to head comparison.
An engine was being constructed for Comp Eliminator style racing and the program was going to be electronically fuel injected. Well the system was giving the engine shop some questionable numbers. The shop removed the EFI system and installed some of our Pro Stock carburetors on the EFI manifold top so they could quickly compare systems.
The engine responded immediately with much faster acceleration rates and a 5 percent improvement in power.
The EFI designer was brought out to the site and try as he might he could not out perform those carburetors. When the session wrapped up carburetors were king by 24 horsepower.
I've heard similar stories and similar claims when comparing systems.
So when we analyze this information it really comes down to a simple fact. Carburetors and Electronic Fuel injection are two completely different systems. They share no concepts and each has a different theory.
EFI's claim is this: I will supply sprayed droplets of fuel at the proper air to fuel ratio all the time.
Carburetors claim: I will supply a pre-emulsed froth of fuel and air into the engine at a preset ratio.
The results proved the analysis of the concepts to be correct. In this case, the carburetor was supplying the engine in question with the proper air to fuel ratio, so the EFI's advantage was gone. Remember, EFI has a computer to tune the engine. You have you. If you know how to tune you'll have the advantage. Carburetors (at the risk of sounding chauvinistic) are a man's game. Guessing rarely works. You have to know how to actually tune an engine.
Remember a carburetor is an atomization/emulsion machine. An injection system is a proper air to fuel delivery ratio machine. Two different concepts. If a carburetor can be designed to supply the perfect air to fuel ratio all the time it should consistently outperform EFI. Its design lends itself to have an unfair advantage in atomization.
Obviously adiabatic expansion is the next question on the list. So if we take a good look at the carburetor we see its not only a perfect machine for atomizing fuel, it also has another advantage. The joule-thompson effect.
Tests performed using quartz plates and infra red sensors located in the plenum area beneath an NHRA Pro-Stock engine revealed an intake manifold temperature drop on a 85 degree day of almost 20 degrees as a result of the the carburetor creating this effect.
So when your neighbor with EFI is ingesting 85 degree air, your power-plant could be ingesting 65 degree air.
That's a nice advantage.
But let's not skip over the atomization advantage. In a high end designed carburetor the fuel is emulsed to lift it. Its a controlled froth. I won't kid you, it's very difficult to control. Its much easier to build a carburetor that operates on a vacuum to ratio concept. But the fogging advantage is gone. So when a customer asks, why is this carburetor more expensive than that builders carburetor as they look basically the same. Most of it is all in the emulsion package and the time spent flowing it and tweaking it to do its job. Remember in a high emulsion design .001 of an inch is a big deal. They're difficult to balance and require sophisticated equipment that many shops have never seen. Also, don't go poking things into the metering block passages to inspect them or look around. You might just lose 10 lbs of torque.
The disadvantage of carburetors used to be restriction. I remember back 20 years ago before booster technology really took off you had to size carburetors to operate on 1-2 inches of vacuum in the plenum at the starting line. The restriction alone was probably costing these engines a 2-3 percent power loss.
Tests we performed at Sonny's racing 5 years ago showed us numbers of about .6 in the plenum and spikes of about 1.1 to 1.3 in the runner at the finish-line. That's a pretty huge decrease and just for dynos sake when we built carburetors large enough to reduce this number by on average 40 percent we saw an increase of only about 3-5 horsepower on an IHRA Pro-Stocker. SO that advantage for EFI is now also gone.
Now that these same engines can operate on as little as .5 hg of vacuum at the starting line and only 1-1.2 at the finish-line, the restriction is nil. Really it all comes down to getting the air to fuel ratio correct. If a carburetor can do that, it should win the race every time. After all, by design, it's a superior emulsion machine.
Thanks for reading.
749142
Sep 17 2008, 08:32 PM
fi becuase,
better gas mpg
its original,
and setup up properly Ljet is the most reliable thing ive had so far.
i heart ljet becuase i never could get the djet to run right. bad narnesses.
djets are good too i just never had any success becuase my harnesses were cracking and breaking. brittle wires.
but oh well carbs arent my style
DBCooper
Sep 17 2008, 08:58 PM
Pro Systems, you mean the drag-racing carburetor manufacturer? Do you suppose they have a point of view? And do they have any concern other than wide-open throttle? Do you drive your 914 at anything less than wide open throttle? If you do then that information is irrelevant.
Ljet and Djet may be primitive compared to more modern fuel injection technologies, but they still deliver better ratios throughout all driving conditions than even more primitive carburetors can. It's easy enough to see that for yourself, how do your carburetors adjust for cold running temperatures? For higher elevations? For higher temperatures?
Spoke
Sep 17 2008, 09:57 PM
I like FI because I could sell my used dual Weber IDF40's for $400 in one day.
Mark Henry
Sep 17 2008, 10:01 PM
Now if your happy with a stock 80/95hp L/D-jet engine then I agree that stock FI is the best, but I'm not so then you're into carbs or PEFI.
Simple as that.
Carbs are not perfect but they can be tuned to a point of being comparable to FI and handle all sorts of mods to the engine. The 180hp (150rwhp) T4 I built runs just as smooth as a 95hp d-jet. My bus with a 2L T1 w/dual DCNF's runs better than stock 1600 with more than twice the power.
Most issues with carbs are user error, poor linkage set-up being #1, followed by engine faults (built bad or worn out) and poor choices on parts. With an solid engine, O2 meter and a set of jet reams I can set the A/F ratio right on the money. (I BTW I find the A/f ratio more stable with carbs). Four years ago I drove my VW squareback all winter, no chokes on my dual weber's down to -25C, never a problem.
If we were talking /6's there is almost no FI vs carb debate..if there's no FI on that /6 then slap some weber's on that puppy.
Guys will spend $3k on PMO's
DBCooper
Sep 17 2008, 10:36 PM
That's why I said a stock engine, that's what we've been talking about.
For modified engines when you have to remove the stock fuel injection then a modern fuel injection system running in closed loop gives even more advantages. Carbs don't change mixtures according to feedback from the engine like FI in closed loop, so they can't provide correct fuel/air ratio for every situation. It's impossible. They simply don't have the physical capacity to do that. You can get carbs to be good, no doubt, but never as good as well tuned fuel injection. Any new performance cars you know of being produced today that use carburetors? Highest buck, no compromise cars running carbs? Even as optional equipment? Why not?
Sure you CAN drive a carbureted car in the winter with no chokes, we've all done it. But you've got to admit that it was primitive and your engine wasn't real efficient or friendly until it was warmed up. And did you try doing that at 8000 feet? That's the whole point, fuel injection gives you the correct air/fuel ratio no matter what the situation. Carburetors don't. They can't.
Put on $3000 PMO's IF there's no FI on the 6? Vroom, vroom.
So.Cal.914
Sep 17 2008, 10:58 PM
I drive mine FT quite often, I built my engine to have fun with. I come out of most
corners at FT. I put my webers on about 25 years ago on a stock engine and the
performance was improved at lowend as well as topend. With the proper cam,
head work, crank and compression it produces plenty of power and Great throttle
responce. It's fun as hell and no matter what some 'know it all dick' says, they are
staying.
DBCooper
Sep 17 2008, 11:36 PM
Great, like everything else on your car, do what you like. It's YOUR car after all. If you modified your engine then carburetors are fine, and 25 years ago when you put yours on they were the logical choice for a modified car. The bright side is that you can look forward to even better performance some day when you put a modern fuel injection system on it.
That's also more proof of what I said earlier, that people who think carbs are better than fuel injection are people who never had their fuel injection working correctly. Too bad you didn't just fix it back then, you'd have had 25 years of having more fun.
LarryR
Sep 17 2008, 11:39 PM
I think you needed a 3rd category aftermarket fuel injection. I voted fuel injection but thinking twm throttle bodies.
dw914er
Sep 17 2008, 11:44 PM
I voted FI. It workes great, and is pretty reliable (until you get some sort of leak). Its also from the factory, and efficient.
TheCabinetmaker
Sep 18 2008, 08:00 AM
See? One more useless thread about FI vs carbs. To each his own. Why get hot and bothered and call someone an dick just because they have a preference? Do you think the guy that drives a Porsche thinks another guy is a dick cause he drives a Ferrari? Bullshit! There are applications where FI works best, and of course, where carbs work best. Why not save your typing skills for something that really matters? If ya wanna argue about useless bullshit, go to the sandbox and post in one of the 1237 useless political threads?
Mark Henry
Sep 18 2008, 08:18 AM
QUOTE(vsg914 @ Sep 18 2008, 10:00 AM)
Most peeps who hate carb's never had a clue on how to set them up proper, but then most peeps who rip off the FI never had it working proper as well.
This thread is pointless.
DBCooper
Sep 18 2008, 09:15 AM
QUOTE(Mark Henry @ Sep 18 2008, 07:18 AM)
Agree totally. And the only people who can really compare are people who've actually done both correctly, well, and more than once.
Can't totally agree with this though. People new to 914's or new to the forums probably need to see this back and forth once in a while to know they have options. It may be a waste of your time because you've seen it and heard it and done it yourself before, but that's not true for everyone.
carcam
Sep 18 2008, 10:50 AM
I'm new and like this thread. What's PMO? I have Webers on my 6 and wouldn't mind a nice FI sometimes. Thanks.
