| stephenaki |
Aug 22 2007, 10:17 PM
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
FNG question again. The 72 914 I just bought has a set of delorto (dellorto?) carbs versus the stock FI set up. I know nothing about these carbs other than that they are very similar to Weber carbs. I am much more familiar with HS2 and HS4 carbs on British cars.
So what is the general thought on carbs versus FI? Should I consider converting it back to FI or just keep and tune the existing carbs? If converting back to FI, how difficult and/or expensive of a project will this be? Enquiring minds want to know. |
| jr91472 |
Aug 22 2007, 10:28 PM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Depends on what is inside the motor. If you still have the stock cam, then the FI will run best. If you have a carb friendly (aftermarket) cam, then stick with the Dells.
How does it run now? Carbs with a stock cam can work fine, just not optimum. Dells are great (most say they flow better than the Webers). I love mine!! (IMG:style_emoticons/default/beer.gif) FNG question again. The 72 914 I just bought has a set of delorto (dellorto?) carbs versus the stock FI set up. I know nothing about these carbs other than that they are very similar to Weber carbs. I am much more familiar with HS2 and HS4 carbs on British cars. So what is the general thought on carbs versus FI? Should I consider converting it back to FI or just keep and tune the existing carbs? If converting back to FI, how difficult and/or expensive of a project will this be? Enquiring minds want to know. |
| stephenaki |
Aug 22 2007, 10:46 PM
Good question, I have no friggin idea and I don't think the guy that I bought it from has any idea either on what cam she's got in her. I am thinking not since the previous owner (the one prior to the guy now) did work on the engine and put in 2.0 jugs.
I may just let sleeping dogs lie, at least until she shows up and I get a chance to drive her around and see how she performs. |
| Eric_Ciampa |
Aug 22 2007, 11:09 PM
CHAMP914 ![]() ![]() Group: Members Posts: 154 Joined: 3-April 03 From: Placerville, CA Member No.: 511 Region Association: Northern California
I just got a 914 running with a set of dells on mine and I am loving it. Jr is right that the stock setup will run the best with FI but I can't tell any measurable distance. I am sure you will get a good amount of opinons on both sides. This is one of those never ending debates. Just my opinion, but just make sure your system is dialed in and your car is running correctly.
| toon1 |
Aug 23 2007, 08:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
FNG question again. The 72 914 I just bought has a set of delorto (dellorto?) carbs versus the stock FI set up. I know nothing about these carbs other than that they are very similar to Weber carbs. I am much more familiar with HS2 and HS4 carbs on British cars. So what is the general thought on carbs versus FI? Should I consider converting it back to FI or just keep and tune the existing carbs? If converting back to FI, how difficult and/or expensive of a project will this be? Enquiring minds want to know. Do a search, there is soooooooooooo much info on this, it will make your head hurt. It boils down to what you like. I am a fan of FI so that's what I have. Simlple as that |
| So.Cal.914 |
Aug 23 2007, 09:03 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
FI sucks, stick with the carbs. (IMG:style_emoticons/default/hide.gif)
QUOTE Do a search, there is soooooooooooo much info on this, it will make your head hurt. It boils down to what you like. I am a fan of FI so that's what I have. Simlple as that Its so true, been discussed, some like FI and some like carbs. For FI its a nice setup if your drive takes you to extreme changes, like altitude and temp. For carbs, I (now this is me) have had less trouble with my webers and I like the performance. (IMG:style_emoticons/default/driving.gif) |
| Joe Ricard |
Aug 23 2007, 11:46 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Tune em and run em as they are.
or Dump tons of money into a hole that you can't see the bottom of. or get some measuring tools and find out what ya got. Then dump tons of money into it. |
| jhadler |
Aug 23 2007, 05:44 PM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
FI sucks, stick with the carbs. (IMG:style_emoticons/default/hide.gif) Actually, carbs suck. And FI blows... (IMG:style_emoticons/default/biggrin.gif) -Josh2 |
| TROJANMAN |
Aug 23 2007, 05:51 PM
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
FI sucks, stick with the carbs. (IMG:style_emoticons/default/hide.gif) Actually, carbs suck. And FI blows... (IMG:style_emoticons/default/biggrin.gif) -Josh2 I always that the joke was: Cal sucks and UCLA swallows (IMG:style_emoticons/default/laugh.gif) (IMG:http://209.85.48.8/9859/38/emo/SC_emoticon.gif) (IMG:style_emoticons/default/biggrin.gif) |
| stephenaki |
Aug 28 2007, 12:50 PM
Interesting banter, don't know much about FI. I know that once my HS2 carbs on my MGs were tuned in you really didn't have to mess with them.
I will be going through some significant altitude changes when I drive back from Sicily, Italy to Stuttgart, Germany. Depending on when the car gets in, October or November, I hope the heater works! Its getting a thorough once over at Euro sports in Virginia Beach, VA before it gets put on a ship. I will look up tuning info on the carbs to get more info, thanks for all the replies. |
| SirAndy |
Aug 28 2007, 01:03 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| toon1 |
Aug 28 2007, 01:21 PM
NO! (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:07 AM |
