CV joint bolts loose |
JJ914 |
Sep 15 2008, 08:27 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Hey my inner cv joint bolts keep getting loose. Thinking of putting a safety wire hole in it aircraft style or maybe some lock tight stuff. I have used new cone washers and they still get loose. What do you think.
Eric_Shea |
Sep 17 2008, 09:40 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Sounds like you didn't have new (or any) Schnorr washers. That's the #1 cause of the bolts working loose.
JJ914 |
Sep 17 2008, 09:49 PM
Sounds like you didn't have new (or any) Schnorr washers. That's the #1 cause of the bolts working loose. I have replaced the washer both times I have had the axles off. Thinking they were not cleaned good enough. But I got new Schnorr's again and cross drilled the bolt so if they come loose again something bad will have happened. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:26 PM |
