914 1975 1.8 A/C Question, Air Conditioning Drive Belt |
chcjr |
Sep 19 2008, 09:46 AM
Newbie Group: Members Posts: 5 Joined: 20-October 06 From: Raleigh, NC Member No.: 7,067 |
My 1975 A/C unit (origionally installed by the dealer) just quit working because the drive belt broke. Could some one please tell me the correct part number so I can buy a new one.
Also, What is the best way to install a new belt. |
maf914 |
Sep 19 2008, 02:11 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Type47's sequence looks pretty good, but you would also have to remove the fan/alternator belt since this is on the outer part of the cooling fan, blocking access past the fan. That said, I am not sure there is enough room between the outer diameter of the cooling fan and the inner diameter of the cooling shroud to work the AC belt past the fan. (IMG:style_emoticons/default/idea.gif)
I think you can tell there is not a lot of first hand experience on the board when it comes to 914's with AC systems. (IMG:style_emoticons/default/laugh.gif) |
type47 |
Sep 19 2008, 06:41 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
you would also have to remove the fan/alternator belt since this is on the outer part of the cooling fan, blocking access past the fan. oh yea, i didn't think of that (IMG:style_emoticons/default/confused24.gif) there is enough room between the outer diameter of the cooling fan and the inner diameter of the cooling shroud to work the AC belt past the fan. (IMG:style_emoticons/default/idea.gif) I think you can tell there is not a lot of first hand experience on the board when it comes to 914's with AC systems. (IMG:style_emoticons/default/laugh.gif) true that. i removed the a/c system on my first 914. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:51 AM |
