Headlight/running light/foglight operation |
1970 Neun vierzehn |
Sep 14 2008, 12:06 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
On a recent thread, a forum member posed a question about the switch function and operation of his ('72/6, French market(-sounds like a coffee blend) 914. I could only surmise what the regulations and specs for that market might have required.
However, there seems to be variation of lighting interface on some USA spec cars that I've seen. My own, unaltered '70/4 works like this. Pull the dash light switch to the first detent and the h/l buckets come up w/o h/l illumination. The front parking lights, side markers and t/ls are illuminated. Pull the switch to the next (and last) detent and the h/ls come on. The fog light switch, next to the h/l switch, illuminates the fog lights whenever it is pulled out, regardless of the position of the h/l switch. Furthermore, I know of unaltered 914s ('72 and later) that when the h/l switch is pulled out to the first detent, the parking/side marker/tail lights are illuminated but the h/l buckets do not come up. The buckets come up and the headlights come on only in the last, final switch position. I do not know if the fog lights can be used independently of the h/l switch position, as on my '70. Running changes? Specification changes? Factory variations? The whim of Hans on the assembly line. (IMG:style_emoticons/default/confused24.gif) Paul |
dw914er |
Sep 20 2008, 10:15 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
one pull is parking lights. Second is headlights pop up and come on. Only then will the fog lights turn on.
Push one click, the headlights and fog lights turn of, but headlights are still popped up. Only when I turn off all lights does the headlights go back down. |
AvalonFal |
Sep 21 2008, 07:22 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
one pull is parking lights. Second is headlights pop up and come on. Only then will the fog lights turn on. Push one click, the headlights and fog lights turn of, but headlights are still popped up. Only when I turn off all lights does the headlights go back down. Same on my '74 2.0L. Paul |
Lo-Fi Version | Time is now: 17th June 2024 - 06:06 AM |
