> Using bondo to fill pad cracks, ???
VaccaRabite
post Sep 29 2008, 08:49 AM
En Garde!
I read a thread a while back (back in the club days) about using bondo to fill cracks in the dash and suck.
For my dash, I'm just capping it. However, my targa pad is cracked, and I was thinking about this as an alternative. Does anyone have experience with it?
My guess would be to cut away the bad material and fill with filler in stages. What would then be used to paint or stain everything black again? Do I want to "seal" the crack with epoxy or some such first? How would I keep the foam and vynal to keep from pulling away from the body filler over time, creating a new, bigger crack?
Zach
smdubovsky
post Sep 30 2008, 08:38 AM
Zach, I've used a vinyl repair kit for my 911 dash. You work some of the goop down into the crack, cover w/ a matching texture pad, then add heat. Voila, almost indistinguishable. Its flexible too so should survive a little longer. If the crack is deep, you might want to fill w/ foam first.
- Lo-Fi Version Time is now: 2nd April 2026 - 06:42 PM
