914chic |
Newbie ![]() Group: Members Posts: 41 Joined: 31-December 07 From: Huntington beach ca Member No.: 8,521 ![]() |
alright well here it is , on one bank the carb fills the carb with fuel the plates even after you shut it off , it doesn't do it on the other carb. Now I also noticed that under the carb that there is a leak wich is coming from what I think is the accelerator pump so I know I need to fix that but I don't see that being the cause of the unwanted fuel , any input greatly appreciated
Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
I would say... before it goes POOF, tend to the fuel leak. Then, and only then... I would say split your lines so they both travel the same distance. Ideally, a T bar would be placed in the middle... and from that T bar an equal distance hose to each carb inlet.
That, of course, assumes you are getting enough fuel (to begin with). C:> |
Lo-Fi Version | Time is now: 4th July 2025 - 01:00 AM |
