Lightweight suggestion, URY!!! |
r_towle |
Jan 12 2004, 08:34 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I seem to recall a thread mentioning that the 911 front cross member that atttaches to the rear of the A-arms and supports the steering rack is made from aluminum???
I do remember moving one of those steel ones the other day and it weighed probably 30 lbs.... Rich |
ArtechnikA |
Jan 12 2004, 10:46 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(r_towle @ Jan 12 2004, 06:34 PM) I seem to recall a thread mentioning that the 911 front cross member that atttaches to the rear of the A-arms and supports the steering rack is made from aluminum??? not 'the' cross-member. 'A' crossmember. specifically, from I-series 911 (1976) and newer, through maybe 1989 (maybe later). 911S and 912E. notably, NOT the 2,7 Carrera RS. it -is- lighter. it is also a lot more flexible. (unlike the 911 rear trailing arms, where the aluminum parts were more rigid than the steel ones they replaced, for a double benefit ...) it is not a -lot- lighter, and the weight is just about as low in the chassis as you can get. i was enamored of the aluminum crossmember until i researched it more. (a reference in Frere's '911 Story' led me to believe it was responsible for a suspension geometry change, but in fact it is identical, dimensionally, to the steel ones, and the geometry change was made to the I-Series tub...). if you're into lightness for its own sake, you might save a pound or two. i prefer to retain rigidity in my front steering and suspension, and the 20 lbs i can "easily" take off the driver are located much higher in the chassis... 911.341.013.10 if you want to track it through the years ... |
Lo-Fi Version | Time is now: 6th June 2024 - 05:16 AM |
