> Pushrod Tube Seals, Are They Single Use Items?
kconway
post Sep 24 2008, 10:35 PM
Welp....I changed out my pushrod tube seals about 6 weeks ago and completely forgot to put the tin on before I put the tubes back in (engine is on a stand). (IMG:style_emoticons/default/chair.gif) Can I pull the tubes back off and reuse the seals if they're not nicked or cut up?
Kev (IMG:style_emoticons/default/flag.gif)
LowGT
post Oct 6 2008, 09:24 PM
1.8 and Proud!
Several have replaced the push rod tube seals with the engine in the car. I don't think you can totally remove the tubes, but you can pull it out enough to replace the seals.
I personally would pull the engine, I don't enjoy working in tight spaces like that.
r_towle
post Oct 6 2008, 09:30 PM
Custom Member
QUOTE(LowGT @ Oct 6 2008, 11:24 PM) *
I find it easier to replace the push rod tube seals in the car.
So long as you dont have a 75/76 with stock HE's...those suck.
Pull of the valve cover
Pull of the rocker assembly
Pull push rod spring
Leave push rods in car (cant get them all out anyways)
Pull push rod tubes...they wont come all the way out.
replace seals
re-assemble.
If you pull the motor, then you need to get it up in the air hihg enough to pull the pushrod tubs out.
Rich
- Lo-Fi Version Time is now: 16th July 2025 - 05:35 PM
