> Injector Size for SDS?, Need help on injectors
Joe Owensby
post Sep 28 2008, 11:22 AM
JoeO
Planning to put a SDS on a 2 liter engine. I intend to use a 2 liter manifold, fuel rail, etc. which I have. I want to put in new injectors as I install this. In browsing around, it looks as if the 2 liter injectors are becomming obsolete or unavailable soon. The 1.8 Ljet injectors seem to be the most commonly used ones on Porsches and other cars. For example, Advance auto has these for $46.00 new, made by Niehoff. Is anyone familiar with Niehoff injectors, and are they good quality?
It seems as if the time to upgrade for long term parts availability is now, as the new control system will be tuned in to the injector size. Is this a good choice? Will the 1.8 Ljet injectors fit the '73 fuel rails and manifold tubes? Are the connectors on these the same as the Ljet connectors being offered with the new aftermarket control systems. Your advice is greatly appreciated.
Or, does anyone have any better suggestion?
Thanks in advance, JoeO
toon1
post Oct 6 2008, 11:56 PM
why don't you go with a different inj. all together?
with a little modification, I used ford prob. inj's ( 21lb's/hr) and ran the FP up at 43 psi.
I got the inj's at pick and pull for 10ea.
They are high imp., readilly avail. and cheap.
I have had them installed with NO prob's. for about 4k miles. They worked great with the MS system because of the high imp., no resistors.
got pics. if interested., just my .02
- Lo-Fi Version Time is now: 13th March 2026 - 07:50 PM
