> Master cylinder issue? Basically new, Leaking fluid like a sieve
JRust
post Oct 7 2008, 09:44 PM
Okay so I haven't been able to drive my car for the last month from overheating issues. I finally got my new renegade radiator installed & solved my cooling issues. Once I am thru with the whole burping process I want to go for a drive. I back up in the driveway to turn around & my foot goes to the floor when I use my brake. I pump the pedal but get nothing. I push the car back in the garage. Pop my hood & check my fluid. Reservoir is bone dry (IMG:style_emoticons/default/WTF.gif)
I pull my access plate below the rack. Everything in place (IMG:style_emoticons/default/confused24.gif) . By the way I replaced this 19mm Master cylinder 3 months ago. It has maybe 500 miles on it tops. I get my bottle of brake fluid & proceed to fill my reservoir. Then peek under my car to see if there is a leak. Heck yeah it is leaking from my master cylinder. I did not have a leak before it was parked??? The fluid is coming from the top of the master cylinder where the feed tubes go into the rubber seals. It is leaking from outside the seals? Coming out very quick? What can I do to fix it? What would cause this? The only thing that has change is I welded in a new section in my front trunk. So there was some heat down there but not that close to the master cylinder. (IMG:style_emoticons/default/WTF.gif)
What do you suggest?
scotty
post Oct 7 2008, 10:00 PM
The Fun Never Stops
I'd check to make sure the seals are in and the lines are properly in the seals.
Is it draining down the feed lines (on the outside) to the MC? Then I'd check to see if there's a hairline crack in one or both of the feed lines.
The reservoir has two separate sections for when it runs low... is it empty in both? Is that a possible failure mode?
I hated putting the lines into my MC last week. After 2 or 3 hours of trying, I went off for "a rest" and when I came back, "snick-snick!" in they went. Bah!
- Lo-Fi Version Time is now: 14th March 2026 - 09:34 AM
